.NET
why using viewport.twistangle affects viewport.viewcenter
3 REPLIES 3
mohamedalmaz6
215 Views, 3 Replies
i am trying to rotate ucs to algine with rotated rectangle in modelspace but when using viewport.twistangle it affects viewport.viewcenter although it algin with center of view if i didnot use viewport.twist angle ot the angle is zero (horizontal rectangle as example)
    Autodesk.AutoCAD.DatabaseServices.ObjectId vpid = layout1.GetViewports()[1];
    Viewport vp = ts.GetObject(vpid, OpenMode.ForWrite) as Viewport;
    var WCS2DCS =
Matrix3d.WorldToPlane(vp.ViewDirection) *
Matrix3d.Displacement(vp.ViewTarget.GetAsVector().Negate()) *
Matrix3d.Rotation(vp.TwistAngle, vp.ViewDirection, vp.ViewTarget);
    var centertrans = centerpoint.TransformBy(WCS2DCS);
    double vpRatio = vp.Width / vp.Height;
    double extWidth = width;
    double extHeight = height;
    double extRatio = extWidth / extHeight;
    double scale = extRatio < vpRatio ? vp.Height / extHeight : vp.Width / extWidth;
    vp.TwistAngle = Math.PI * 2 - angle;
    vp.ViewCenter = new Point2d(centertrans.X, centertrans.Y);
    vp.ViewDirection = Vector3d.ZAxis;
    vp.CustomScale=scale;
@_gile
3 REPLIES 3
_gile
in reply to: mohamedalmaz6
What about setting the Viewport.TwistAngle before computing the WCS2DCS matrix?
Gilles Chanteau
GileCAD
GitHub
mohamedalmaz6
in reply to: _gile
yes your idea has worked
thanks gile
but why it affects it
how just computing the transformation matirx overwrite anything
_gile
thanks gile
If you attentively read the transformation matrix code, you can see it is built from the the viewport ViewDirection, ViewTarget and TwistAngle values. That's why you have to set these properties before building the transformation matrix and use it to transform the 'centerpoint'.
Gilles Chanteau
GileCAD
GitHub
Forma Design Contest
AutoCAD Beta
