.NET
try to insert blocks without attributes - nothing to see
2 REPLIES 2
jan_tappenbeck
391 Views, 2 Replies
hi!
currently i try to insert blocks from a Folder.
there comes no mistake but at the end no block will be visible. Select all will not filter any block!
could someone help me? the code follows now.
regards Jan
Public Function CreateInsertNoAttribut(ByVal InsertPoint As Point3d, ByVal TbDoc As Autodesk.Map.IM.Forms.Document, ByVal AlternativeBlockFolder As String, ByVal AlternativeBlockName As String, ByVal Orientation As Double, ByVal BlockName As String) As Integer
        ' ------ http://ma22-wiki-001/eblwiki/index.php?title=Acad_(Klasse_von_EBL.MapService)#Block ------
        '' Get the current document and database
        Dim acDoc As Autodesk.AutoCAD.ApplicationServices.Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acDoc.Database
        Dim ErrDetail As String = ""
        Dim Options As EBL.Optionen.Options = New EBL.Optionen.Options(TbDoc)
        Dim BlockFilePath As String = ""
        BlockName = BlockName & ".dwg"
        BlockFilePath = Path.Combine(Options.GetPathFolderBlockDM, BlockName)
        ' wenn Block nicht verfügbar, dann Dummyblock
        If System.IO.File.Exists(BlockFilePath) = False Then
            BlockFilePath = Path.Combine(Options.GetPathFolderBlockDM, AlternativeBlockName)
            BlockName = AlternativeBlockName
        Dim br As BlockReference
        Dim id As ObjectId
        Try
            ErrDetail = "Start a transaction"
            Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                ErrDetail = "Open the Block table for read"
                Dim acBlkTbl As BlockTable
                ErrDetail = "lock document"
                Using acDoc.LockDocument
                    Using TempDB As New Database(False, True)
                        'Get block table
                        acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite, False)
                        'check if block already exists
                        If Not acBlkTbl.Has(BlockName) Then
                            'check if file exists
                            If IO.File.Exists(BlockFilePath) Then
                                'read in the file into the temp database
                                TempDB.ReadDwgFile(BlockFilePath, IO.FileShare.Read, True, Nothing)
                                'insert the tempdb into the current drawing db, id is the new block id
                                id = acCurDb.Insert(BlockName, TempDB, True)
                        Else
                            id = acBlkTbl.Item(BlockName)
                        'create a new block reference
                        br = New BlockReference(New Point3d(0, 0, 0), id)
                    End Using
                End Using 'acDoc.LockDocument
                ErrDetail = "Save the changes and dispose of the transaction"
                acTrans.Commit()
            End Using 'acTrans
        Catch ex As Exception
            _TryReport.Show("unerwarteter Fehler in EBL.MapService > cls_Acad > CreateInsertNoAttribut", "ErrDetail: " & ErrDetail & vbCrLf & vbCrLf & _
        "Orientation: " & Orientation.ToString & vbCrLf & _
 vbCrLf & ex.ToString)
            Return 1
        End Try
        Return 0
    End Function
2 REPLIES 2
_gile
in reply to: jan_tappenbeck
You neither append the newly created block reference to a block table record (e.g. model space) nor add it to the transaction...
Gilles Chanteau
GileCAD
GitHub
jan_tappenbeck
in reply to: _gile
hi !
thanks - now it works!
regards Jan
    Public Function CreateInsertNoAttribut(ByVal InsertPoint As Point3d, ByVal TbDoc As Autodesk.Map.IM.Forms.Document, _
                                           ByVal AlternativeBlockFolder As String, ByVal AlternativeBlockName As String, _
        Dim id As ObjectId
        Try
                    'use a temporary database
                        'Get block table
                        Dim acBlkTblRec As BlockTableRecord
                        acBlkTblRec = CType(acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite), BlockTableRecord)
                        Else
                        br = New BlockReference(InsertPoint, id)
                        acBlkTblRec.AppendEntity(br)
                        acTrans.AddNewlyCreatedDBObject(br, True)
                    End Using
                acTrans.Commit()
            End Using 'acTrans
        "AlternativeBlockFolder: " & AlternativeBlockFolder & vbCrLf & _
        "AlternativeBlockName: " & AlternativeBlockName & vbCrLf & _
        "BlockName: " & BlockName & vbCrLf & _
            Return 1
        End Try
        Return 0
    End Function
Forma Design Contest
AutoCAD Beta
