Stacking Ribbon Panel
I am trying to achieve the stacking button panel like the 'modify' panel in the 'Home' tab (Picture Below).
How do I achieve this with a C# plugin?
Jeff_M
Use the RibbonPanelBreak.
using Autodesk.AutoCAD.Runtime;
using Autodesk.Windows;
namespace AutoCADTest
    public class Class1
        [CommandMethod("testmyRibbon", CommandFlags.Transparent)]
        public void Testme()
            RibbonControl ribbon = ComponentManager.Ribbon;
            if (ribbon != null)
                RibbonTab rtab = ribbon.FindTab("TESTME");
                if (rtab != null)
                    ribbon.Tabs.Remove(rtab);
                rtab = new RibbonTab();
                rtab.Title = "TEST  ME";
                rtab.Id = "Testing";
                //Add the Tab
                ribbon.Tabs.Add(rtab);
                addContent(rtab);
        static void addContent(RibbonTab rtab)
            rtab.Panels.Add(AddOnePanel());
        static RibbonPanel AddOnePanel()
            RibbonButton rb;
            RibbonRowBreak rbrk;
            RibbonPanelSource rps = new RibbonPanelSource();
            rps.Title = "Test One";
            RibbonPanel rp = new RibbonPanel();
            rp.Source = rps;
            //Create a Command Item that the Dialog Launcher can use,
            // for this test it is just a place holder.
            RibbonButton rci = new RibbonButton();
            rci.Name = "TestCommand";
            //assign the Command Item to the DialgLauncher which auto-enables
            // the little button at the lower right of a Panel
            rps.DialogLauncher = rci;
            rb = new RibbonButton();
            rb.Name = "Test Button 1";
            rb.ShowText = true;
            rb.Text = "Test Button 1";
            //Add the Button to the Tab
            rps.Items.Add(rb);
            rbrk = new RibbonRowBreak();
            rps.Items.Add(rbrk);
            rb.Name = "Test Button 2";
            rb.ShowText = true;
            rb.Text = "Test Button 2";
            rps.Items.Add(rb);
            rb.Name = "Test Button 3";
            rb.ShowText = true;
            rb.Text = "Test Button 3";
            rps.Items.Add(rb);
            RibbonPanelBreak rpbrk = new RibbonPanelBreak();
            rps.Items.Add(rpbrk);
            rb.Name = "Test Button 4";
            rb.ShowText = true;
            rb.Text = "Test Button 4";
            rps.Items.Add(rb);
            return rp;
Jeff_M, also a frequent Swamper
