Hi all,
So I've ran into a problem. When I try to make layouts in bulk it takes too long, because when it creates new layouts it automatically generates viewports one at a time and then zooms to extents of the objects in model space within the VP before adjusting the viewport to where it actually needs to go before moving onto the next layout.
The problem is that the file is rather large, so every time it generates a viewport and automatically zooms out to extents that makes AutoCAD render the entire drawing after each viewport is generated. This makes every layout takes 5 seconds or so to prepare before I can move onto the next layout in the iteration, and if you have 200 layouts or so obviously this gets to be an impractical problem.
My question is, is there a way to do this more quickly? I feel like there should be a way to add these viewports pre-zoomed, or not have to make the layout being edited current before moving on, truly anything would work.
Here's what I have so far (note I made some arbitrary changes like how many layouts get created so that this is more testable/readable):
<CommandMethod("ASGOT")>
Public Sub CreateLayoutsWithViewport()
Dim acAppComObj As Object = Application.AcadApplication
Dim acPrefComObj As Object = acAppComObj.Preferences
' Store the current setting
Dim originalSetting As Boolean = acPrefComObj.Display.LayoutCreateViewport
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim db As Database = doc.Database
Try
' Change the setting to prevent automatic viewport creation
acPrefComObj.Display.LayoutCreateViewport = False
For i As Integer = 1 To 3
Dim layoutName As String = "NewLayout" & i
CreateLayout(db, layoutName)
CreateViewport(db, layoutName)
Next
Catch ex As Exception
doc.Editor.WriteMessage("Error in creating layouts with viewports: " & ex.Message)
Finally
' Restore the original setting
acPrefComObj.Display.LayoutCreateViewport = originalSetting
End Try
End Sub
Private Sub CreateLayout(db As Database, layoutName As String)
Using tr As Transaction = db.TransactionManager.StartTransaction()
Dim lm As LayoutManager = LayoutManager.Current
If Not lm.LayoutExists(layoutName) Then
lm.CreateLayout(layoutName)
lm.CurrentLayout = layoutName
tr.Commit()
End Using
End Sub
Private Sub CreateViewport(db As Database, layoutName As String)
Dim layoutId As ObjectId = lm.GetLayoutId(layoutName)
Dim layout As Layout = tr.GetObject(layoutId, OpenMode.ForWrite)
Dim btr As BlockTableRecord = tr.GetObject(layout.BlockTableRecordId, OpenMode.ForWrite)
Using vp As New Viewport()
btr.AppendEntity(vp)
tr.AddNewlyCreatedDBObject(vp, True)
vp.CenterPoint = New Point3d(5.25, 4.0, 0.0)
vp.Width = 8.4
vp.Height = 6.4
Dim minPoint As Point2d = New Point2d(1448444.1609, 624876.8246)
Dim maxPoint As Point2d = New Point2d(1449418.8916, 625525.3315)
vp.ViewCenter = New Point2d((minPoint.X + maxPoint.X) / 2, (minPoint.Y + maxPoint.Y) / 2)
vp.ViewHeight = maxPoint.Y - minPoint.Y
vp.On = True
End Using
tr.Commit()
End Using
End Sub
Solved by bdean123456. Go to Solution.
You could try to freeze everything but the essential layers during batch creation to speed up the process? If you have not already unloaded any references, that would speed it up as well.
