.NET
Select only Text and Mtext objectss
9 REPLIES 9
Message 1 of 10
J-Rocks
1228 Views, 9 Replies
Hello everyone .
It seems that my TypedValue structure is wrong because I could not select Texts or Mtext nor anything when I ran the program . strange Smiley Happy
Could someone help me to modify the codes ?
TypedValue[] Tvalues = new TypedValue[] { new TypedValue(0, "TEXT"), new TypedValue(0, "MTEXT") };
9 REPLIES 9
Message 2 of 10
J-Rocks
in reply to: J-Rocks
It seems this modification is working with wild-cards .
Is this correct ?
TypedValue[] Tvalues = new TypedValue[] { new TypedValue(0, "*TEXT") };
Message 3 of 10
your last pattern call is correct, but also try to separate the pattern with commas, in example:
TypedValue[] typedValues = { new TypedValue((int)DxfCode.Start, "LINE,ARC,LWPOLYLINE,POLYLINE,CIRCLE,SPLINE,ELLIPSE") };
hth.-
Message 4 of 10
J-Rocks
Thanks LE that works very well .
I am trying to write a program to select text strings that match a specific text string "BedRoom" , and my question is : how can I highlight if the list contained values ( text strings "BedRoom" ) ?
Regards
            using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
                Editor ed = acDoc.Editor;
                TypedValue[] Tvalues = new TypedValue[] {new TypedValue((int)DxfCode.Start,"TEXT,MTEXT")};
                SelectionFilter fltr = new SelectionFilter(Tvalues);
                PromptSelectionResult SSprompt;
                SSprompt = acDoc.Editor.GetSelection(fltr);
                if (SSprompt.Status == PromptStatus.OK)
                    foreach (SelectedObject item in SSprompt.Value)
                        DBObject obj = acTrans.GetObject(item.ObjectId, OpenMode.ForRead) as DBObject;
                        MText mtext = obj as MText;
                        if (mtext != null && mtext.Contents=="BedRoom")
                            mylist.Add(mtext.Contents);
                            ed.WriteMessage(mtext.Contents + System.Environment.NewLine);
                        else
                            DBText text = obj as DBText;
                            if (text != null && text.TextString == "BedRoom")
                                mylist.Add(text.TextString);
                                ed.WriteMessage(text.TextString + System.Environment.NewLine);
Message 5 of 10
that sounds like you want to have a similar Find (built-in-command) tool, looks like you maybe able to use the TextEditor Class - read about this on the arxmgd.chm - it might help.
Message 6 of 10
J-Rocks
I read about this TextEditor class but it seems a little bit difficult to a biginner guy like me , can you give me an example if it is not that bothering ?
Thank you
Message 7 of 10
sorry, don't have time for that, and also no need for a tool like this as i am not an autocad user anymore.
maybe there is something already there (similar) never knows in the net, good luck!
Message 8 of 10
see, KEAN WALMSLEY great site about autocad, has an usage sample of this class:
http://through-the-interface.typepad.com/through_the_interface/2010/06/changing-the-case-of-an-mtext...
just need to do a search.... hth.-
Message 9 of 10
This uses extension methods that are posted at the swamp but should be easy to tell what little typing it saves
for example
var mtxt = item.GetEntity<MText>();
///////Change to
        private static IntPtr mtxtPtr = RXObject.GetClass(typeof(MText)).UnmanagedObject;
        [CommandMethod("roomnameHighlight")]
        public void roomnameHighlight()
            using (Transaction trx = Db.TransactionManager.StartTransaction())
                AllowedClassFilter acf = new AllowedClassFilter(typeof(MText), typeof(DBText));
                PromptSelectionResult selResult = Ed.GetSelection(acf);
                if (selResult.Status != PromptStatus.OK){return;}
                    foreach (var item in selResult.Value.GetObjectIds())
                        if (item.ObjectClass.UnmanagedObject == mtxtPtr)
                            if (mtxt.Text.Equals("RoomName", StringComparison.OrdinalIgnoreCase))
                                mtxt.Highlight();
                        else
                            var txt = item.GetEntity<DBText>();
                            if (txt.TextString.Equals("RoomName", StringComparison.OrdinalIgnoreCase))
                                txt.Highlight();
                trx.Commit();
Message 10 of 10
J-Rocks
Thank you jeff for your help .
I have an error on
Intptr
and
AllowedClassFilter
but the HighLight Method works and I just add it to my codes and it works , though I am looking for a way to SELECT and not just to HIGHLIGHT.
The HighLight method is not clear enough to see the highlighted objects if I have many objects .
Thank you.
Forma Design Contest
AutoCAD Beta
