.NET
Run command when .dll is loaded
1 REPLY 1
My_Civil_3D
203 Views, 1 Reply
Hi i am looking for a method to impement a way to check certain autocad variable settings every time the dll is loaded( autocad starts).  Is there a way other than command method to run commands without the user launching them?
Civil 3D Certified Professional
1 REPLY 1
norman.yuan
in reply to: My_Civil_3D
A class that implement IExtensionApplication would always run the Initialize() method when the DLL is loaded:
public class MyPlugin : IExtensionApplication
    // this method is called when the DLL is loaded
    public void Initialize()
        // you code here to check the MdiActiveDocument settings
        // you may also handle DocumentCreated event, so that whenever
        // a new drawing or a drawing file is opened, you can also check the
       // drawing settings
    // this method is called when AutoCAD quits
    public void Terminate()
         // in most cases you probably do not need to do anything here
   // your other code of the class goes here...
Make sure you use try...catch to wrap the code in the Initialize(), if the code may result in runtime exception.
Norman Yuan
Drive CAD With Code
AutoCAD Inside the Factory
