.NET
Region From 3d polyline
2 REPLIES 2
hosneyalaa
1711 Views, 2 Replies
hi all
I'm trying to make a region out of Polyline3d
Build
But I get a message like in the picture
It is a possible helper to solve the error
Thank you all
The original code from the page
https://www.theswamp.org/index.php?topic=43572.0
/// BrepSamples.cs (excerpt)  Copyright (c) 2008  Tony Tanzillo
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.BoundaryRepresentation; // acdbmgdbrep.dll
using Autodesk.AutoCAD.Geometry;
using AcBr = Autodesk.AutoCAD.BoundaryRepresentation;
using ErrorStatus = Autodesk.AutoCAD.Runtime.ErrorStatus;
namespace BRepSamples
    public static class Containment
        /// <summary>
        /// This variation performs point contianment testing
        /// against any closed curve from which a simple region
        /// (e.g., no inner-loops) can be genreated, using the
        /// Region.CreateFromCurves() API.
        /// </summary>
        [CommandMethod("testCURVECONTAINMENT")]
        public static void CurveContainmentCommand()
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            ObjectId id = GetCurve(ed, "\nSelect a closed Curve: ");
            if (!id.IsNull)
                using (Transaction tr = ed.Document.TransactionManager.StartTransaction())
                    try
                        Curve curve = (Curve)id.GetObject(OpenMode.ForRead);
                        if (!curve.Closed)
                            ed.WriteMessage("\nInvalid selection, requires a CLOSED curve");
                            return;
                        if (id.ObjectClass == RXObject.GetClass(typeof(Polyline3d)))
                                var poly3d = (Polyline3d)tr.GetObject(id, OpenMode.ForWrite);
                                var space = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                            try
                                Polyline poly2dx = new Polyline();
                                int j = 0;
                                foreach (ObjectId vid in poly3d)
                                    PolylineVertex3d v3d = (PolylineVertex3d)tr.GetObject(vid, OpenMode.ForRead);
                                    var planez = new Plane(Point3d.Origin, Vector3d.ZAxis);
                                    //poly2dx.AddVertexAt(j, new Point3d(v3d.Position.X, v3d.Position.Y, v3d.Position.Z).Convert2d(planez), 0, 0, 0);
                                    poly2dx.AddVertexAt(j, new Point2d(v3d.Position.X, v3d.Position.Y), 0, 0, 0);
                                    j++;
                                poly2dx.Closed = true;
                                space.AppendEntity(poly2dx);
                                tr.AddNewlyCreatedDBObject(poly2dx, true);
                                Curve curve0 = (Curve)poly2dx.Id.GetObject(OpenMode.ForRead);
                                using (Region region = RegionFromClosedCurve(curve))
                                    PromptPointOptions ppo = new PromptPointOptions("\nSelect a point: ");
                                    ppo.AllowNone = true;
                                    while (true) // loop while user continues to pick points
                                        /// Get a point from user:
                                        PromptPointResult ppr = ed.GetPoint(ppo);
                                        if (ppr.Status != PromptStatus.OK)  // no point was selected, exit
                                            break;
                                        // use the GetPointContainment helper method below to
                                        // get the PointContainment of the selected point:
                                        PointContainment containment = GetPointContainment(region, ppr.Value);
                                        // Display the result:
                                        ed.WriteMessage("\nPointContainment = {0}", containment.ToString());
                            catch (System.Exception ex)
                                Application.ShowAlertDialog(ex.Message);
                        else
                                    break;
                    finally
                        tr.Commit();
        // this helper method takes a Region and a Point3d that must be
        // in the plane of the region, and returns the PointContainment
        // of the given point, adjusted to correctly indicate its actual
        // relationship to the region (inside/on boundary edge/outside).
        public static PointContainment GetPointContainment(Region region, Point3d point)
            PointContainment result = PointContainment.Outside;
            /// Get a Brep object representing the region:
            using (Brep brep = new Brep(region))
                if (brep != null)
                    // Get the PointContainment and the BrepEntity at the given point:
                    using (BrepEntity ent = brep.GetPointContainment(point, out result))
                        if (ent is AcBr.Face)
                            result = PointContainment.Inside;
            return result;
        public static Region RegionFromClosedCurve(Curve curve)
            if (!curve.Closed)
                throw new ArgumentException("Curve must be closed.");
            DBObjectCollection curves = new DBObjectCollection();
            curves.Add(curve);
            using (DBObjectCollection regions = Region.CreateFromCurves(curves))
                if (regions == null || regions.Count == 0)
                    throw new InvalidOperationException("Failed to create regions");
                if (regions.Count > 1)
                    throw new InvalidOperationException("Multiple regions created");
                return regions.Cast<Region>().First();
        public static PointContainment GetPointContainment(Curve curve, Point3d point)
            if (!curve.Closed)
            Region region = RegionFromClosedCurve(curve);
            if (region == null)
                throw new InvalidOperationException("Failed to create region");
            using (region)
                return GetPointContainment(region, point);
        public static ObjectId GetCurve(Editor editor, string msg)
            PromptEntityOptions peo = new PromptEntityOptions(msg);
            peo.SetRejectMessage("Invalid selection: requires a closed Curve,");
            peo.AddAllowedClass(typeof(Curve), false);
            PromptEntityResult res = editor.GetEntity(peo);
            return res.Status == PromptStatus.OK ? res.ObjectId : ObjectId.Null;
2 REPLIES 2
Your problem is with the polyline3D in the drawing.
The polyline3d is not planar, so it is not possible to make a region of it.
You can check if the selected polyline3d is planar with the following command:
polyline3d.IsPlanar
Which is a boolean value (True/False).
Thank you
I forgot to change the item
using (Region region = RegionFromClosedCurve(curve0))
Forma Design Contest
AutoCAD Beta
