.NET
Region Bounding Box In 3D Coordinate
7 REPLIES 7
Message 1 of 8
thannaingoo.api
1650 Views, 7 Replies
Dear All,
How to get region bounding box in 3D coordinate?
I used below code to extract the bounding box of a region.
The result is not same as massprop value.
How should I get the correct value of region bounding box base on the current coordinate system?
Naing Oo
var region = (Region)tr.GetObject(id, OpenMode.ForWrite, false, true);
                                if (region.Area > 0.0)
                                    Point3d max = region.Bounds.Value.MaxPoint;
                                    Point3d min = region.Bounds.Value.MinPoint;
                                    Application.ShowAlertDialog(min.ToString() + "\n" + max.ToString());
7 REPLIES 7
Message 2 of 8
The below link shows how to transform from one coordinate system to another.
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-NET/files/GUI...
(In your case you will have to go from the WCS to UCS.)
Message 3 of 8
I still can't get the right value. Below image green color is region and the red color is a bounding box from the result.
How should I fix it? Below is the latest code.
Naing Oo
                                    Point3d MaxPoint = region.Bounds.Value.MaxPoint;
                                    Point3d MinPoint = region.Bounds.Value.MinPoint;
                                    Point3d max = MaxPoint.TransformBy(Matrix3d.PlaneToWorld(region.Normal));
                                    Point3d min = MinPoint.TransformBy(Matrix3d.PlaneToWorld(region.Normal));
                                    Application.ShowAlertDialog(max.ToString() + "\n" + min.ToString());
Message 4 of 8
_gile
in reply to: thannaingoo.api
You have to transform the region object from current UCS to WCS, get the extents, and transform back the region to UCS.
var region = (Region)tr.GetObject(id, OpenMode.ForWrite);
                region.TransformBy(ed.CurrentUserCoordinateSystem.Inverse());
                var extents = region.GeometricExtents;
                region.TransformBy(ed.CurrentUserCoordinateSystem);
                ed.WriteMessage($"\nBoundingBox about UCS: {extents.MinPoint} {extents.MaxPoint}");
Gilles Chanteau
GileCAD
GitHub
Message 5 of 8
thannaingoo.bim.mep
in reply to: _gile
Dear @_gile,
Thank you for the reply.
I got the wrong value for 45degree rotated region object along Zaxis.
Please, Let me know the way how to solve it.
Naing Oo
Message 6 of 8
thannaingoo.api
in reply to: _gile
I am trying to create a rectangle of region object bounding box in 3D coordinate.
Let me know the way to create a bounding box rectangle.
Naing Oo
Message 7 of 8
_gile
If I do not misuderstand, what you want to achieve is not related to the current UCS. it is related to the region OCS.
Try like this:
        [CommandMethod("RegionToBoundingBoxRectangle")]
        public static void RegionToBoundingBoxRectangle()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var peo = new PromptEntityOptions("\nSelect region: ");
            peo.SetRejectMessage("\nSelected object is not a Region.");
            peo.AddAllowedClass(typeof(Region), true);
            var per = ed.GetEntity(peo);
            if (per.Status != PromptStatus.OK)
                return;
            var id = per.ObjectId;
            using (var tr = db.TransactionManager.StartTransaction())
                // get the region plane normal
                var normal = region.Normal;
                var plane = new Plane(Point3d.Origin, normal);
                // transform the region from WCS to OCS
                region.TransformBy(Matrix3d.WorldToPlane(plane));
                // get the 'bounding box'
                // transform bak the region from OCS to WCS
                region.TransformBy(Matrix3d.PlaneToWorld(plane));
                // get the plane elevation
                var elevation = extents.MaxPoint.Z;
                // get the bounding box coorinates (OCS)
                var minX = extents.MinPoint.X;
                var minY = extents.MinPoint.Y;
                var maxX = extents.MaxPoint.X;
                var maxY = extents.MaxPoint.Y;
                // create a rectangle (Polyline)
                var pline = new Polyline(4);
                pline.AddVertexAt(0, new Point2d(minX, minY), 0.0, 0.0, 0.0);
                pline.AddVertexAt(1, new Point2d(maxX, minY), 0.0, 0.0, 0.0);
                pline.AddVertexAt(2, new Point2d(maxX, maxY), 0.0, 0.0, 0.0);
                pline.AddVertexAt(3, new Point2d(minX, maxY), 0.0, 0.0, 0.0);
                pline.Closed = true;
                pline.Normal = normal;
                pline.Elevation = elevation;
                var curSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                curSpace.AppendEntity(pline);
                tr.AddNewlyCreatedDBObject(pline, true);
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
Message 8 of 8
thannaingoo.api
in reply to: _gile
Dear @_gile,
I want to thank you for taking the time out to answer my question. I am sure that you are busy, and I appreciate you taking the time to respond. Thank you again.
Naing Oo
Forma Design Contest
AutoCAD Beta
