.NET
Pline jig with double
1 REPLY 1
1220 Views, 1 Reply
hi
I want to modify Kean Walmsely polyline Jig. For before every point user will be asked for entering double (nadsloj) and this double will be subtacted form points y value (cent).
Here is class code:
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Geometry;
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
namespace prolazi
    class PlineJig : EntityJig
        // Maintain a list of vertices...
        // Not strictly necessary, as these will be stored in the
        // polyline, but will not adversely impact performance
        Point3dCollection m_pts;
        // Use a separate variable for the most recent point...
        // Again, not strictly necessary, but easier to reference
        Point3d m_tempPoint;
        Plane m_plane;
        double nadsloj = 1;
        double cent;
        double promjerC = 300;
        public PlineJig(Matrix3d ucs)
            : base(new Polyline())
            // Create a point collection to store our vertices
            m_pts = new Point3dCollection();
            // Create a temporary plane, to help with calcs
            Point3d origin = new Point3d(0, 0, 0);
            Vector3d normal = new Vector3d(0, 0, 1);
            normal = normal.TransformBy(ucs);
            m_plane = new Plane(origin, normal);
            // Create polyline, set defaults, add dummy vertex
            Polyline pline = Entity as Polyline;
            pline.SetDatabaseDefaults();
            pline.Normal = normal;
            pline.AddVertexAt(0, new Point2d(0, 0), 0, 0, 0);
        protected override SamplerStatus Sampler(JigPrompts prompts)
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            JigPromptPointOptions jigOpts =
              new JigPromptPointOptions();
            jigOpts.UserInputControls =
              (UserInputControls.Accept3dCoordinates |
              UserInputControls.NullResponseAccepted |
              UserInputControls.NoNegativeResponseAccepted
            //JigPromptOptions jpo = new JigPromptOptions();
            if (m_pts.Count == 0)
                // For the first vertex, just ask for the point
                jigOpts.Message =
                  "\nStart point of polyline: ";
            else if (m_pts.Count > 0)
                //cent = funkcije.odnadsloj(nadsloj) + promjerC * 0.0005;
                // For subsequent vertices, use a base point
                jigOpts.BasePoint = m_pts[m_pts.Count - 1];
                jigOpts.UseBasePoint = true;
                jigOpts.Message = "\nPolyline vertex: ";
            else // should never happen
                return SamplerStatus.Cancel;
            // Get the point itself
            PromptPointResult res =
              prompts.AcquirePoint(jigOpts);
            // Check if it has changed or not
            // (reduces flicker)
            if (m_tempPoint == res.Value)
                return SamplerStatus.NoChange;
            else if (res.Status == PromptStatus.OK)
                m_tempPoint = res.Value;
                //m_tempPoint = new Point3d(res.Value.X, res.Value.Y - cent, 0);
                return SamplerStatus.OK;
        protected override bool Update()
            // Update the dummy vertex to be our
            // 3D point projected onto our plane
            pline.SetPointAt(
              pline.NumberOfVertices - 1,
              m_tempPoint.Convert2d(m_plane)
            return true;
        public Entity GetEntity()
            return Entity;
        public void AddLatestVertex()
            Point3d k = new Point3d(m_tempPoint.X, m_tempPoint.Y - cent, 0);
           //_tempPoint = k;
            m_pts.Add(k);
            // Create a new dummy vertex...
            // can have any initial value
            pline.AddVertexAt(
              pline.NumberOfVertices,
              new Point2d(0, 0),
              0, 0, 0
        public void RemoveLastVertex()
            // Let's remove our dummy vertex
            pline.RemoveVertexAt(m_pts.Count);
 Here is function code:
[CommandMethod("MYPOLY")]
        public void MyPolyJig()
            Document doc =
            // Get the current UCS, to pass to the Jig
            Matrix3d ucs =
              ed.CurrentUserCoordinateSystem;
            // Create our Jig object
            PlineJig jig = new PlineJig(ucs);
            // Loop to set the vertices directly on the polyline
            bool bSuccess = true, bComplete = false;
            do
                PromptResult res = ed.Drag(jig);
                bSuccess =
                  (res.Status == PromptStatus.OK);
                // A new point was added
                if (bSuccess)
                    jig.AddLatestVertex();
                // Null input terminates the command
                bComplete =
                  (res.Status == PromptStatus.None);
                if (bComplete)
                    // Let's clean-up the polyline before adding it
                    jig.RemoveLastVertex();
            } while (bSuccess && !bComplete);
            // If the jig completed successfully, add the polyline
            if (bComplete)
                // Append entity
                Transaction tr =
                  db.TransactionManager.StartTransaction();
                using (tr)
                    BlockTable bt =
                      (BlockTable)tr.GetObject(
                        db.BlockTableId,
                        OpenMode.ForRead,
                        false
                    BlockTableRecord btr =
                      (BlockTableRecord)tr.GetObject(
                        bt[BlockTableRecord.ModelSpace],
                        OpenMode.ForWrite,
                        false
                    btr.AppendEntity(jig.GetEntity());
                    tr.AddNewlyCreatedDBObject(jig.GetEntity(), true);
                    tr.Commit();
 I tried everthing is it posable to do this?
1 REPLY 1
Balaji_Ram
Here is a sample code to demonstrate acquiring a point and double input alternately using a jig.
It aquires the width for each vertex point of the polyline and sets the polyline width at the vertex.
This code does not alter the y coordinate as you seem to be trying. But I think this code can help as a starting point for your implementation.
    double m_Width = 1.0;
    Plane m_plane;
    public bool InputAcquirePoint { get; set; }
    public PlineJig(Matrix3d ucs) : base(new Polyline())
        if (InputAcquirePoint)
            JigPromptPointOptions jigOpts = new JigPromptPointOptions();
            jigOpts.UserInputControls = (UserInputControls.Accept3dCoordinates | UserInputControls.NullResponseAccepted | UserInputControls.NoNegativeResponseAccepted);
                jigOpts.Message = "\nStart point of polyline: ";
                jigOpts.Message = "\nNext point of the Polyline : ";
            PromptPointResult res = prompts.AcquirePoint(jigOpts);
        else
            JigPromptDistanceOptions jigOpts = new JigPromptDistanceOptions();
            jigOpts.Message = "\nWidth : ";
            PromptDoubleResult pdr = prompts.AcquireDistance(jigOpts);
            if (m_Width == pdr.Value)
            else if (pdr.Status == PromptStatus.OK)
                m_Width = pdr.Value;
        pline.SetPointAt(pline.NumberOfVertices - 1, m_tempPoint.Convert2d(m_plane));
        return true;
        return Entity;
        Point3d k = new Point3d(m_tempPoint.X, m_tempPoint.Y, 0);
        m_pts.Add(k);
        pline.AddVertexAt(pline.NumberOfVertices, new Point2d(0, 0), 0, m_Width, m_Width);
    public void AddLatestWidth()
        if (m_pts.Count == 1)
            pline.SetStartWidthAt(m_pts.Count - 1, m_Width);
            pline.SetEndWidthAt(m_pts.Count - 1, m_Width);
        else
            pline.SetEndWidthAt(m_pts.Count - 2, m_Width);
Here is the code to use the Jig class
        Document doc =
        Matrix3d ucs = ed.CurrentUserCoordinateSystem;
        jig.InputAcquirePoint = true;
        do
            bSuccess = (res.Status == PromptStatus.OK);
            if (bSuccess)
                if(jig.InputAcquirePoint)
                else
                    jig.AddLatestWidth();
                jig.InputAcquirePoint = ! jig.InputAcquirePoint;
            bComplete = (res.Status == PromptStatus.None);
            if (bComplete)
        if (bComplete)
            // Append entity
            Transaction tr =
            using (tr)
                BlockTable bt =
                    db.BlockTableId,
                    OpenMode.ForRead,
                    false
                    OpenMode.ForWrite,
                    false
                tr.Commit();
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
Forma Design Contest
AutoCAD Beta
