Open DWG save as DXF with API VB.NET or C#
florian_wenzel
florian_wenzel
i need some Help.
I try to Open Each .DWG File in a Folder(Directory)
Save Document as .DXF
Thanks for any Suggestion
florian_wenzel
Why i get Error:
    <CommandMethod("OpenDrawingDWG", CommandFlags.Session)>
    Public Sub OpenDrawingDWG()
        Dim strFileName As String = "C:\AutoCad_API\CAD\20221024\Folder_A\Test_ver2018_b.dwg"
        Dim strFileNameSave As String = "C:\AutoCad_API\CAD\20221024\Folder_A\Test_ver2018_b.dxf"
        Dim acDocMgr As DocumentCollection = Application.DocumentManager
        DocumentCollectionExtension.Open(acDocMgr, strFileName, False)
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim strDWGName As String = acDoc.Name
        MsgBox("strFileNameSave = " & strFileNameSave)
        acDoc.Database.DxfOut(strFileNameSave, 16, DwgVersion.Current)
    End Sub
Error:
Second Code:
        acDoc.Database.SaveAs(strFileNameSave, True, DwgVersion.AC1027, acDoc.Database.SecurityParameters)
    End Sub
Save File as DXF, but the File is Empty
When i try to open the File, than i get Blackscreen and Text " Press Enter to go Forward" but the File is Empty
Thanks for Any Suggestion!
_gile
You should use a 'side database' (i.e. open the dwg in memory) instead of opening the dwg in the editor.
Here's an exemple:
        private static void SaveAsDxf(string dwgName)
            using (var db = new Database(false, true))
                db.ReadDwgFile(dwgName, FileOpenMode.OpenForReadAndAllShare, true, null);
                string dxfName = System.IO.Path.ChangeExtension(dwgName, "dxf");
                db.DxfOut(dxfName, 16, true);
Gilles Chanteau
GileCAD
GitHub
florian_wenzel
Thanks for Solution
Thanks for Help
