System.AccessViolationException while trying to get layername
r00teniy
r00teniy
Hello, I am getting "System.AccessViolationException: Attempted to read or write protected memory." while trying go get layer of blockref in array.
Here is part of the code that give exeption, it always gives it then i try to get (obj as BlockReference).Layer, if i remove it, it works fine:
                    if (AssocArray.IsAssociativeArray(objectId))
                        using (BlockReference br = objectId.Open(OpenMode.ForRead) as BlockReference)
                            using (DBObjectCollection brs = new DBObjectCollection())
                                br.Explode(brs);
                                if (brs != null && brs.Count > 0)
                                    foreach (DBObject obj in brs)
                                        for (int j = 0; j < laylistBL.Length; j++)
                                            if (obj is BlockReference && (obj as BlockReference).Layer == laylistBL[j])
                                                TableValues[12 + j] += 1;
                                            obj.Dispose();
I found similar code and modified it for myself here.
Can you please point out what I'm doing wrong?
_gile
hi,
What if you iterate through the BlockTableRecord entities of the BlockReference instead of exploding it?
Something like this (not tested).
    using (BlockReference br = (BlockReference)objectId.Open(OpenMode.ForRead))
        using (BlockTableRecord btr = (BlockTableRecord)br.BlockTableRecord.Open(OpenMode.ForRead))
            foreach (objectId id in btr)
                if (id.ObjectClass.Name = "AcDbBlockReference")
                    using(BlockReference bRef = (BlockReference)id.Open(OpenMode.ForRead))
                            if (bRef.Layer == laylistBL[j])
Gilles Chanteau
GileCAD
GitHub
r00teniy
Thank you, will try to work in this direction.
_gile
Oops!...
I forgot casting the BlockTableRecord.
I corrected the upper code replacing:
using (BlockTableRecord btr = br.BlockTableRecord.Open(OpenMode.ForRead))
with:
Gilles Chanteau
GileCAD
GitHub
r00teniy
For me this line did it, thank you:
using (BlockTableRecord btr = br.DynamicBlockTableRecord.Open(OpenMode.ForRead) as BlockTableRecord)
