.NET
.Net Console app to Convert DWG to PDF
2 REPLIES 2
702 Views, 2 Replies
Need to create a .NET Console App that will loop through all files in Folder and convert each DWG to PDF.
This will be run without an UI as a batch file.
2 REPLIES 2
jtoverka
Use the AutoCAD Core Console
There is a related Core Console PDF Generation
If you know C# .NET you can even create an application to run the Core Console in the background. Otherwise you can just run scripts from the console.
Hi!
Will give it a try.
Forma Design Contest
AutoCAD Beta
