.NET
mutliple attributes
0 REPLIES 0
Message 1 of 1
160 Views, 0 Replies
mutliple attributes
ive been following the c# labs, and have tried to modify the code so that my block has 2 attributes.
defining the AttributeReference outside the loop results in only 1 attribute making it into the inserted block.
defining the attref inside the loop as below, results in an error when run in CAD, but compiles fine...
can anyone point me in the right direction
many thanks,
dom
using System;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Colors;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
[assembly: CommandClass(typeof(ClassLibrary.HPDVClass))]
namespace ClassLibrary
/// Summary description for HPDVClass.
public class HPDVClass
public HPDVClass()
// TODO: Add constructor logic here
// Define Command "CREATE"
[CommandMethod("CREATE")]
static public void CreateEmployee()
//declare some stuff
Database db = HostApplicationServices.WorkingDatabase;
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
//start transaction
Transaction trans = db.TransactionManager.StartTransaction();
try
//access block table for write
BlockTable bt = (BlockTable)trans.GetObject(db.BlockTableId, OpenMode.ForWrite);
//create the reference
BlockReference bRef = new BlockReference(new Point3d(0, 0, 0), CreateEmployeeDefinition());
//access modelspace
BlockTableRecord btr = (BlockTableRecord)trans.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
//create new attribute ref
//AttributeReference attRef = new AttributeReference();
BlockTableRecord empBtr = (BlockTableRecord)trans.GetObject(bt["EmpBlock"],OpenMode.ForRead);
foreach (ObjectId id in empBtr)
Entity ent = (Entity)trans.GetObject(id, OpenMode.ForRead);
if (ent is AttributeDefinition)
AttributeDefinition attDef = ((AttributeDefinition)(ent));//wtf is this!?
//match the properties
attRef.SetPropertiesFrom(attDef);
attRef.Position = new Point3d(attDef.Position.X + bRef.Position.X, attDef.Position.Y + bRef.Position.Y,
attDef.Position.Z + bRef.Position.Z);
attRef.Height = attDef.Height;
attRef.Rotation = attDef.Rotation;
attRef.Tag = attDef.Tag;
attRef.TextString = attDef.TextString;
bRef.AttributeCollection.AppendAttribute(attRef);
trans.AddNewlyCreatedDBObject(attRef, true);
btr.AppendEntity(bRef);
attRef.Dispose();
//btr.AppendEntity(bRef);
//bRef.AttributeCollection.AppendAttribute(attRef);
trans.AddNewlyCreatedDBObject(bRef, true);
//trans.AddNewlyCreatedDBObject(attRef, true);
trans.Commit();
catch
//error message
ed.WriteMessage ("FAIL in CreateEmployee");
finally
//dispose of objects
trans.Dispose();
db.Dispose();
0 REPLIES 0
”Boost
