.NET
Moving Annotative Object to Current Anno Scale
4 REPLIES 4
My_Civil_3D
307 Views, 4 Replies
I am trying to make a command that the user selects items in the drawing and the goal is to remove the current annotative scales for that item and  move it to the current set annotative scale. i dont just want to add the current it needs to remove the old ones first.
the reason why i split the different objects is because i assume that they all have different ways to set the annotative scales. the alert dialog box was to check if i selects a correct object. This Is what i have so far but i am stuck
  public void AttachToCurrentAnnoScale()
      Document doc = Application.DocumentManager.MdiActiveDocument;
      Database db = doc.Database;
      Editor edt = doc.Editor;
      ObjectContextManager ocm = db.ObjectContextManager;
      ObjectContextCollection occ = ocm.GetContextCollection("ACDB_ANNOTATIONSCALES");
      AnnotationScale currentAnnoScale = db.Cannoscale;
      Application.MainWindow.Focus();
      using (DocumentLock docLock = doc.LockDocument())
          using (Transaction trans = db.TransactionManager.StartTransaction())
              //Create TypedValue
              TypedValue[] types = new TypedValue[]
          new TypedValue((int)DxfCode.Operator, "<or"),
          new TypedValue((int)DxfCode.Start, "INSERT"),
          new TypedValue((int)DxfCode.Start, "MTEXT"),
          new TypedValue((int)DxfCode.Start, "MULTILEADER"),
          new TypedValue((int)DxfCode.Start, "DIMENSION"),
          new TypedValue((int)DxfCode.Operator, "or>")
              //Create SelectionFilter
              SelectionFilter filter = new SelectionFilter(types);
              //Create PromptStringResult
              PromptSelectionResult selResult = edt.GetSelection(filter);
              //Selection Verification
              if (selResult.Status == PromptStatus.OK)
                  //Create Selection Set
                  SelectionSet ss = selResult.Value;
                  //Loop Thru Selection Set
                  foreach (SelectedObject selObj in ss)
                      DBObject dbobj = trans.GetObject(selObj.ObjectId, OpenMode.ForWrite);
                      if (dbobj != null)
                          //Check For Block
                          if (dbobj is BlockReference blockref)
                              Application.ShowAlertDialog("You Selected a Block");
                          //Check For Mtext
                          if (dbobj is MText mtext)
                              mtext.Annotative = AnnotativeStates.True;
                              Application.ShowAlertDialog("You Selected a MTEXT");
                          //Check for MLeader
                          if (dbobj is MLeader mleader)
                              mleader.Annotative = AnnotativeStates.True;
                              Application.ShowAlertDialog("You Selected a MLeader");
                          //Check for Dimension
                          if (dbobj is Dimension dim)
                              dim.Annotative = AnnotativeStates.True;
                              Application.ShowAlertDialog("You Selected a Dimension");
                  trans.Commit();
                  edt.WriteMessage("\nObject Moved to Current Annotation Scale.");
              else
                  edt.WriteMessage("\nNo valid entities selected. Ensure the correct types are being selected.");
 THis
Civil 3D Certified Professional
4 REPLIES 4
You can use dbobj.RemoveContext() in a loop for all Annotation Scales, then dbobj.AddContext() to add the current one. Here you find some examples btw:
https://www.keanw.com/2011/10/delete-all-but-current-annotation-scales-on-autocad-objects-using-net....
Just a side note: you don't move objects to a scale, you apply a scale to an object 🙂
My_Civil_3D
in reply to: My_Civil_3D
this works but there is an issue when it comes to mleaders. it applies the scales but it doesnt change. i have a lisp file i have used for a long time and when using the lisp it works fine but this doesnt seem to work correctly with mleaders even though they are set annotative and changes when changing manually
Gepaha
        public void AddCurrentAnnoScaleAndRemoveOthers()
            Editor ed = doc.Editor;
            SelectionFilter sf = new SelectionFilter(types);
            PromptSelectionResult psr = ed.GetSelection(sf);
            if (psr.Status != PromptStatus.OK)
                return;
            ObjectId[] ids = psr.Value.GetObjectIds();
            if (ocm == null)
                return;
                foreach (ObjectId id in ids)
                    Entity ent = trans.GetObject(id, OpenMode.ForWrite) as Entity;
                    if (ent == null)
                        continue;
                    if (ent.Annotative == AnnotativeStates.True)
                        if (!ent.HasContext(db.Cannoscale))
                            ent.AddContext(db.Cannoscale);
                        foreach (ObjectContext oc in occ)
                           if (ent.HasContext(oc) && oc.Name != db.Cannoscale.Name)
                                ent.RemoveContext(oc);
                    else
                        ent.Annotative = AnnotativeStates.True;
                trans.Commit();
My_Civil_3D
Very interesting. Thank you i am trying to learn as much as possible as i go along i have done some online course but it seems the mountain
Forma Design Contest
