.NET
LoadOnCommandInvocation and autocomplete causing command not to work
3 REPLIES 3
573 Views, 3 Replies
So I am new to .net.
I was previously installing my program by adding the registry entries manually (Oops!)
I have now changed to using the Autoloader and PackageContents.xml.
The program is correctly loaded, as some commands will work immediately. Other commands do not work if they are the first command to be run on after starting autoCAD.
I believe this to be autoCAD's autocomplete feature. The commands that do not work are not recognized but close enough to an existing command for autocad to 'Autocorrect' them.
Once I have run a command that does not autocorrect, all other commands then work fine.
I've tried changing LoadOnCommandInvocation to false but it didn't appear to change an thing. Any help?
<?xml version="1.0" encoding="utf-8"?>
<ApplicationPackage SchemaVersion="1.0" AutodeskProduct="AutoCAD" ProductType="Application" Name="DrgNo" AppVersion="1.0.0" Description="MBVE Plugin: DrgNo" Author="Redacted" Icon=".\Contents\Resources\DH.png" AppNameSpace="" OnlineDocumentation="Redacted" HelpFile="./Contents/Resources/DrgNoHelp.htm" ProductCode="Redacted" UpgradeCode="Redacted" SupportedLocales="Enu">
  <CompanyDetails Name="Vital Energi" Phone=" " Url="Reacted" Email="Redacted" />
  <Components>
    <RuntimeRequirements SupportPath="./Contents/Resources" OS="Win32|Win64" Platform="AutoCAD|Civil3D|Map|AIS|ADT|ACADM|MEP|ACADE|PNID|Plant3D|Civil|LDT" SeriesMin="R20.1" SeriesMax="R20.1" />
    <ComponentEntry AppName="DrgNo" Version="1.0.0" ModuleName="./Contents/Windows/GetDrgNo.dll" AppDescription="MBVE: DrgNo" LoadOnCommandInvocation="False" LoadOnRequest="True">
      <Commands GroupName="MBVEDRGNO">
<Command Global="DrgNo" />
<Command Global="Stamp" />
<Command Global="Scalebar" />
<Command Global="IB" />
<Command Global="GBP" />
<Command Global="ImportBlocks" />
      </Commands>
    </ComponentEntry>
    <ComponentEntry AppName="DrgNo" Version="1.0.0" ModuleName="./Contents/Resources/DH.cuix" AppDescription="MBVE: DRGNO" LoadOnAutoCADStartup="True" />
  </Components>
</ApplicationPackage>
3 REPLIES 3
_gile
I think you're right, AutoCAD autocomplete cannot recognize your commands while the DLL is not loaded and the DLL won't load until one of your command is launched.
So, if you can/want, change the command names so that autocomplete do not find a match with an existing command. It's a good practice to prefix your GroupName and Command names with some symbol (your Registered Developer's Symbol if any).
Or change the plugin load reasons to: LoadOnAutoCADStartup="True".
Gilles Chanteau
GileCAD
GitHub
in reply to: _gile
Hi Gile,
Thanks for the reply. Your previous posts have been very helpful before!
I have since posting read the white paper here:
http://adndevblog.typepad.com/autocad/2013/01/autodesk-autoloader-white-paper.html
I have tried removing loadOnCommandInvocation and defining LoadOnStartup = "True", but AutoCad is still not recognizing my commands.
I have also added local and global commands using a developers symbol.
However, autocorrect will still not pick up my commands!
It will pick up commands after using one that does not autocomplete, but not before. Even with the below .xml
I would also like a resolution that doesn't mean shoehorning commands into what is left over from autocomplete as this inhibits sensible naming!
<ApplicationPackage SchemaVersion="1.0" AutodeskProduct="AutoCAD" ProductType="Application" Name="DrgNo" AppVersion="1.0.0" Description="MBVE Plugin: DrgNo" Author="Redacted" Icon=".\Contents\Resources\DH.png" AppNameSpace="" OnlineDocumentation="Redacted" HelpFile="./Contents/Resources/DrgNoHelp.htm" ProductCode="{42CEC65C-2145-4344-8242-E65D7992C1B8}" UpgradeCode="{8AB3852F-C9CF-4460-9A6B-E43D93F5091F}" SupportedLocales="Enu">
  <CompanyDetails Name="Vital Energi" Phone=" " Url="Redacted" Email="Redacted" />
  <Components>
    <ComponentEntry AppName="DrgNo" Version="1.0.0" ModuleName="./Contents/Windows/GetDrgNo.dll" AppDescription="MBVE: DrgNo" LoadOnAutoCADStartup = "True">
<CommandLocal="DrgNo"Global="MBVE_DrgNO"/>
<CommandLocal="Stamp"Global="MBVE_Stamp"/>
<CommandLocal="Scalebar"Global="MBVE_Scalebar"/>
<CommandLocal="IB"Global="MBVE_IB/>
<CommandLocal="GBP"Global="MBVE_GBP"/>
<CommandLocal="ImportBlocks"Global="MBVE_ImportBlocks"/>
      </Commands>
    </ComponentEntry>
  </Components>
in reply to: _gile
Hi Gile,
Nevermind, I think trying to do local and global names messed something up.
LoadOnStartup = "True" works with the below .xml
Not the greatest solution since I would prefer to demand load, but maybe I will split the plugin so that I limit what I load on startup.
Thanks.
<ApplicationPackage SchemaVersion="1.0" AutodeskProduct="AutoCAD" ProductType="Application" Name="DrgNo" AppVersion="1.0.0" Description="MBVE Plugin: DrgNo" Author="Martin Brookes" Icon=".\Contents\Resources\DH.png" AppNameSpace="" OnlineDocumentation="https://vitalenergi.cloudapp.net/busdev/energysolutions/Pages/default.aspx" HelpFile="./Contents/Resources/DrgNoHelp.htm" ProductCode="{42CEC65C-2145-4344-8242-E65D7992C1B8}" UpgradeCode="{8AB3852F-C9CF-4460-9A6B-E43D93F5091F}" SupportedLocales="Enu">
  <CompanyDetails Name="Vital Energi" Phone=" " Url="https://vitalenergi.cloudapp.net/busdev/energysolutions/Pages/default.aspx" Email="martin.brookes@vitalenergi.co.uk" />
  <Components>
      </Commands>
    </ComponentEntry>
  </Components>
Technology Administrators
