.NET
Table Cell Content Color - Trouble
6 REPLIES 6
908 Views, 6 Replies
I'm in great need of help!!
I'm using c# and I've created a table & i want to give certain cells' contents in that table a different color:
my table is called: t1
AcadDocument myDocument;
t1.SetCellContentColor(row,column, AcadAcCmColor)
I can't understand this "AcadAcCmColor"
I've tried this code:
AcadAcCmColor color = myDocument.application.GetInterfaceObject("AutoCAD.AcCmColor.16");
color.SetRGB(255,0,0);
t1.SetCellContentColor(2,1,color);
but i get this error
Run-Time Error ... Problem in loading application
please help me step by step to set the color of this cell
Thank you
6 REPLIES 6
Call GetCellColor() or whatever the name of the method that
returns the existing color is, modify the resulting AcadAcCmColor
object it returns, and then pass that to SetCellContentColor()
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5831411@discussion.autodesk.com...
Thank you
Tony Tanzillo , Thank You, man
It worked like a charm
Thanx a million 🙂
Hi I'm having a similar issue, trying to set the colour variables, using ColorIndex:
my code is as follows:
AcadAcCmColor col;
AcadAcCmColor col2;
AcadAcCmColor col3;
col.ColorIndex = 90;
col.ColorIndex = 253;
col.ColorIndex = 3;
PressTable.SetCellContentColor(LstRow, 0, col3);
Can anyone point me in the right direction?
_gile
it looks like you're assigning the ColorIndex property 3 times to same instance (col)...
Gilles Chanteau
GileCAD
GitHub
in reply to: _gile
sorry that was a typo
AcadAcCmColor col;
AcadAcCmColor col2;
AcadAcCmColor col3;
col2.ColorIndex = 253;
col3.ColorIndex = 3;
the error is the color index not being set, the variables need to be a AcadAcCmColor to work in the SetCellContentColour method.
_gile
You need to create new instances of AcadAcCmColor before assigning them a color. An then, use the AcColor enum for the color index value.
AcadAcCmColor col = new AcadAcCmColor();
col.ColorIndex = (AcColor)3; // or AcColor.acGreen;
PressTable.SetCellContentColor(0, 0, col);
But if you can use the .NET API instead of the COM API, you can simply do:
table.Cells[0, 0].ContentColor = Color.FromColorIndex(ColorMethod.ByAci, 3);
Gilles Chanteau
GileCAD
GitHub
Technology Administrators
