.NET
Load linetype with textstyle
2 REPLIES 2
fieldguy
399 Views, 2 Replies
I have found several posts on how to load a line type. But, now I need to know if the line type definition uses a text style, and if it does, I need to load it before I can load the line type.
Is there a way to determine if the line type definition includes a text style and it's name?
Maybe I have to read the .lin file as text and check each line for "[]"?
2 REPLIES 2
_gile
in reply to: fieldguy
The LinetypeTableRecord.ShapeStyleAt() method returns the ObjectId of the TextStyleTableRecord of the text if any.
Gilles Chanteau
GileCAD
GitHub
fieldguy
in reply to: _gile
Thank you - I should have dug a little deeper.
There is an example >>here<<
Forma Design Contest
AutoCAD Beta
