I was searching the net and I came up with this cool post from @norman.yuan.
apart of the nice graphic work, I was thinking is it possible to do the same with any kind of block reference?
but not with its bounding box. line, getting the most intersections of a block reference according to a selected point from user?
Solved by norman.yuan. Go to Solution.
I just published an article as the answer to your question, please see the link below, where you can also download the source code. Hope it helps.
https://drive-cad-with-code.blogspot.com/2023/09/find-tangential-touch-points-of.html
Norman Yuan
