.NET
import blocks -- unhandled access violation reading exception
26 REPLIES 26
Message 1 of 27
wokeyiyognshenme
950 Views, 26 Replies
civil3d 2018, C#
I have a  blocks.dwg . There are 64 block definition in blocks.dwg.
I want import all of them into current dwg.
sometimes , the code works.
sometimes , CAD crush:  FAtal error : unhandled access violation reading 0X00F0 exception AT cb3f8b8h !!!!!!!
private void button_import_block_Click(object sender, EventArgs e)
            Document doc = CADAPP.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            using (doc.LockDocument())
                ImportBlocks(db, @"d:\blocks.dwg");
        public void ImportBlocks(Database destDb, string filename)
            try
                // Read the DWG into a side database
               Database sourceDb = new Database(false, true);
                ObjectIdCollection blockIds = new ObjectIdCollection();
                //The exception is perhaps due to the fact the source dwg is opened.
                //Use FileOpenMode.OpenForReadAndAllShare instead  of System.IO.FileShare.Read
                //sourceDb.ReadDwgFile(filename, System.IO.FileShare.Read, true, "");
                sourceDb.ReadDwgFile(filename, FileOpenMode.OpenForReadAndAllShare, true, "");
                sourceDb.CloseInput(true);// make sure the dwg is fully read
                // Create a variable to store the list of block identifiers
                Autodesk.AutoCAD.DatabaseServices.TransactionManager tm = sourceDb.TransactionManager;
                using (Transaction myT = tm.StartTransaction())
                    // Open the block table
                    BlockTable bt = (BlockTable)tm.GetObject(sourceDb.BlockTableId, OpenMode.ForRead, false);
                    // Check each block in the block table
                    foreach (ObjectId btrId in bt)
                        BlockTableRecord btr = (BlockTableRecord)tm.GetObject(btrId, OpenMode.ForRead, false);
                        // Only add named & non-layout blocks to the copy list
                        if (!btr.IsAnonymous && !btr.IsLayout)
                            blockIds.Add(btrId);
                        btr.Dispose();
                    myT.Commit();
                // Copy blocks from source to destination database
                IdMapping mapping = new IdMapping();
                sourceDb.WblockCloneObjects(blockIds, destDb.BlockTableId, mapping, DuplicateRecordCloning.Replace, false);
                mapping.Dispose();
                sourceDb.Dispose();
            catch (Autodesk.AutoCAD.Runtime.Exception ex)
                this.rtx1.AppendText("error:" + ex.Message + "\n");
26 REPLIES 26
Message 2 of 27
_gile
in reply to: wokeyiyognshenme
Try this way:
        public static void ImportBlocks(Database destDb, string filename)
            var ids = new ObjectIdCollection();
            using (var sourceDb = new Database(false, true))
                sourceDb.ReadDwgFile(filename, FileOpenMode.OpenForReadAndReadShare, false, null);
                using (var tr = sourceDb.TransactionManager.StartTransaction())
                    var bt = (BlockTable)tr.GetObject(sourceDb.BlockTableId, OpenMode.ForRead);
                    foreach (ObjectId id in bt)
                        var btr = (BlockTableRecord)tr.GetObject(id, OpenMode.ForRead);
                            ids.Add(id);
                    tr.Commit();
                var mapping = new IdMapping();
                destDb.WblockCloneObjects(ids, destDb.BlockTableId, mapping, DuplicateRecordCloning.Replace, false);
Gilles Chanteau
GileCAD
GitHub
Message 3 of 27
wokeyiyognshenme
in reply to: _gile
your code doesn't work。
private void button8_Click(object sender, EventArgs e)
Editor ed = doc.Editor;
ImportABC();
 // Error: ePermanentlyErased。
targetDb.WblockCloneObjects(ids, targetDb.BlockTableId, mapping, DuplicateRecordCloning.Replace, false);
Message 4 of 27
_gile
Could you try it again, I corrected the code.
Gilles Chanteau
GileCAD
GitHub
Message 5 of 27
wokeyiyognshenme
in reply to: _gile
your code doesn't work.
I try it twice .
first time :
Unhandled Access Violation Reading 0x0170 Exception at CC3F58BFh
second time:
Unhandled Access Violation Reading 0x0128 Exception at CC3F58BFh
private void button10_Click(object sender, EventArgs e)
ImportBlocks_gile(db, @"d:\abclqh.dwg");
----- following is your code -----
public void ImportBlocks_gile (Database destDb, string filename)
ids.Add(id);
tr.Commit();
Message 6 of 27
_gile
It works for me when calling from this command:
        [CommandMethod("IMPORTBLOCKS")]
        public void Test()
            var db = HostApplicationServices.WorkingDatabase;
            ImportBlocks_gile(db, @"D:\abclqh.dwg");
Gilles Chanteau
GileCAD
GitHub
Message 7 of 27
wokeyiyognshenme
in reply to: _gile
did you try my dwg file abclqh.dwg?
Message 8 of 27
wokeyiyognshenme
in reply to: _gile
could you try it in winform ?
Message 9 of 27
_gile
Do you show your WinForm as modal or modeless dialog?
Could you provide the code you use to show the WinForm?
Gilles Chanteau
GileCAD
GitHub
Message 10 of 27
_gile
I tried with your "abclqh.dwg" file and the 3 following commands (simple command, modal dialog, modeless dialog) an they all worked.
It looks like you have a problem with the access to your "abclqh.dwg" file on your computer.
Commands class:
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Runtime;
using System;
using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace ImportBlocksSample
    public class Commands
        public static void ImportBlocksCommand()
            var doc = AcAp.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            ImportBlocks(db, @"D:\abclqh.dwg");
        [CommandMethod("IMPORTBLOCKSMODALDIALOG")]
        public static void ImportBlocksModalDialog()
            using (var modalDialog = new ImportBlocksDialog())
                AcAp.ShowModalDialog(modalDialog);
        static ImportBlocksDialog modelessDialog;
        [CommandMethod("IMPORTBLOCKSMODELESSDIALOG")]
        public static void ImportBlocksModelessDialog()
            if (modelessDialog == null)
                modelessDialog = new ImportBlocksDialog();
            AcAp.ShowModelessDialog(modelessDialog);
            try
                    sourceDb.ReadDwgFile(filename, FileOpenMode.OpenForReadAndAllShare, false, null);
                                ids.Add(id);
                        tr.Commit();
                AcAp.ShowAlertDialog("Blocks importation succeeded");
            catch(System.Exception ex)
                AcAp.ShowAlertDialog(ex.Message);
ImportBlocksDialog class:
using System;
using System.Windows.Forms;
    public partial class ImportBlocksDialog : Form
        public ImportBlocksDialog()
            InitializeComponent();
        private void ImportButton_Click(object sender, EventArgs e)
                Commands.ImportBlocks(db, @"D:\abclqh.dwg");
            DialogResult = DialogResult.OK; // <- this is to close the form if shown as modal dialog
Note that in case of a modeless dialog it would be safer to directly call the IMPORTBLOCKS command wirh SendStringToExecute (to let AutoCAD take care of locking the document).
            doc.SendStringToExecute("IMPORTBLOCKS\n", false, false, false);
Gilles Chanteau
GileCAD
GitHub
Message 11 of 27
wokeyiyognshenme
in reply to: _gile
var testForm = new TestForm();
testForm.ShowInTaskbar = true;
testForm.Show();
Message 12 of 27
_gile
You should not use;
testForm.Show();
to display your dialogs you should use:
Application.ShowModelessDialog(testForm);
See this old but still relevant topic from Kean Walmsley's blog and this other one from the developper's documentation.
That said, according you want to use as modeless form, as said upper, you should define a simple command (as the upper IMPORTBLOCKS) and call this method with SendStringToExecute from the button event handler.
Gilles Chanteau
GileCAD
GitHub
Message 13 of 27
wokeyiyognshenme
in reply to: _gile
I need modalless winform.
So I test your code  .
start AutoCAD 2019
in cad , i  netload Commands.dll.
in editor, i Enter command:"IMPORTBLOCKSMODELESSDIALOG",
then the ImportBlocksDialog show as modelessDialog.
then click button .
first time ,it is ok.
then i  Create a new file ,click the button, it's ok.
then i  Create a new file  again,click the button, it's ok.
....after some times....
then i  Create a new file  again,click the button, CAD crush.
unhandled access violation reading 0x0108 exception at C9775B8FH
Message 14 of 27
wokeyiyognshenme
in reply to: _gile
 i test the most safer method:
i test 30 times.----create 30  new dwg files.
all is ok.
CAD does not crush.
But I need modaless winform.
Message 15 of 27
wokeyiyognshenme
in reply to: _gile
i test the method:
using System;
            try
                                ids.Add(id);
                        tr.Commit();
            catch (System.Exception ex)
second time ,create a new dwg file ,click the button ,it is ok
after several time ---- about 10 times
CAD crush
 unhandled access violation reading 0x0100 exception at C9775B8FH
Message 16 of 27
_gile
Difficult to diagnose.
Perhaps you read the source DWG many times too quickly.
Try to force a garbage collection after the newly created Database is disposed.
            try
                                ids.Add(id);
                        tr.Commit();
                GC.Collect(); // <- forces a garbage collection
Gilles Chanteau
GileCAD
GitHub
Message 17 of 27
wokeyiyognshenme
in reply to: _gile
I try the following code .
            rtx1.Clear();
            var listname = Commands.ImportBlocks_listname(@"D:\abclqh.dwg");
            foreach (var item in listname)
                rtx1.AppendText(item + hh);
            rtx1.AppendText("---" + hh);
            foreach (var name in listname)
                rtx1.AppendText("-- read --" + name +  hh);
                    Commands.only_sourceDb_ReadDwgFile(  @"D:\abclqh.dwg" );
            rtx1.AppendText("----all ok-----" + hh);
public static List<string> ImportBlocks_listname(string filename)
            List<string> listName = new List<string>();
            try
                                listName.Add(btr.Name);
                        tr.Commit();
                AcAp.ShowAlertDialog("get List name OK");
            return listName;
        public static void only_sourceDb_ReadDwgFile(string filename )
            try
                        tr.Commit();
1、 first dwg , it is ok .
2 、create a new dwg file ,and click the button .  it's ok
3 、create a new dwg file ,and click the button .  windows 10 crush, pop up a window : not enough memory.
i restart my computer.Try again.
my computer memory is  16GB.
but i find that ,in the windows 10 Task Manager,  the 16GB is nearly full
2. second time ,CAD Crush.
so , i think ,  using (var sourceDb = new Database(false, true))  don't really dispose the sourceDb , don't realy release the memory.
Message 18 of 27
_gile
Look at my last reply about garbage collection.
Gilles Chanteau
GileCAD
GitHub
Message 19 of 27
wokeyiyognshenme
in reply to: _gile
first dwg ,it is ok, but computer memory still  quickly become full.  gc.collect()  doesn't work.
then create a new dwg , click the buton , after a few seconds , CAD crush.
            try
                        tr.Commit();
Message 20 of 27
wokeyiyognshenme
in reply to: _gile
sourceDb.CloseInput(true);// try it
both doesn't work.
            try
                        tr.Commit();
            rtx1.Clear();
            for (int i = 0; i < 60; i++)
                rtx1.AppendText("-- i --" + i + hh);
                    Commands.only_sourceDb_ReadDwgFile(@"D:\abclqh.dwg");
Forma Design Contest
AutoCAD Beta
