Solved by Virupaksha_aithal. Go to Solution.
Please take a look at blog http://through-the-interface.typepad.com/through_the_interface/2014/04/supporting-autocad-2015s-dark... which explain supporting both (dark/light) theme in AutoCAD. You can use PNG or ICO.
My conclusion is that the better is to create 2 distinct icons for Dark and Light Custom Ribbons using transparent background (RGB: 192,192,192). Checking the sysvariable COLORTHEME it is possible to identify the active scheme.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/again-about-supporting-dark-and-ligh... has additional information.
