how to turn on "Plot with plot styles" in the code?
hi, I tried to print in black and white. I found, if "Plot with plot styles" is checked, then it's black and white. but if it's not checked, then the output still colored. how I can make sure "Plot with plot styles" is checked in my code.
here is my code
private static bool PublishFile(string outputFilename,
string mediaName,
string styleSheetName,
string plotDeviceName,
int intStdScaleType)
PlotRotation myPlotRotation = PlotRotation.Degrees000;
bool ret = false;
BlockTableRecord btr = Active.Database.CurrentSpaceId.GetObject<BlockTableRecord>();
Layout lo = btr.LayoutId.GetObject<Layout>();
// We need a PlotInfo object linked to the layout
PlotInfo pi = new PlotInfo();
pi.Layout = btr.LayoutId;
// We need a PlotSettings object based on the layout settings which we then customize
PlotSettings ps = new PlotSettings(lo.ModelType);
ps.CopyFrom(lo);
// The PlotSettingsValidator helps create a valid PlotSettings object
PlotSettingsValidator psv = PlotSettingsValidator.Current;
// We'll plot the extents, centered and scaled to fit
psv.SetPlotType(ps, Autodesk.AutoCAD.DatabaseServices.PlotType.Extents);
psv.SetUseStandardScale(ps, true);
//psv.SetStdScaleType(ps, StdScaleType.ScaleToFit);
StdScaleType myStdScaleType = StdScaleType.ScaleToFit;
if (Enum.IsDefined(typeof(StdScaleType), intStdScaleType))
myStdScaleType = (StdScaleType)intStdScaleType;
psv.SetStdScaleType(ps, myStdScaleType);
try
//psv.SetPlotCentered(ps, true);
psv.SetPlotCentered(ps, false);
psv.SetPlotOrigin(ps, new Point2d(0, 0));
//psv.SetPlotPaperUnits(ps, PlotPaperUnit.Inches);
//psv.SetPlotPaperUnits(ps, PlotPaperUnit.Millimeters);
psv.SetPlotRotation(ps, myPlotRotation);
catch (System.Exception caught)
throw;
// print in color or black/white
psv.RefreshLists(ps);
psv.SetCurrentStyleSheet(ps, styleSheetName);
psv.SetPlotConfigurationName(ps, plotDeviceName, mediaName);
// We need to link the PlotInfo to the PlotSettings and then validate it
pi.OverrideSettings = ps;
PlotInfoValidator piv = new PlotInfoValidator();
piv.MediaMatchingPolicy = MatchingPolicy.MatchEnabled;
piv.Validate(pi);
// A PlotEngine does the actual plotting (can also create one for Preview)
if (PlotFactory.ProcessPlotState == ProcessPlotState.NotPlotting)
PlotEngine pe = PlotFactory.CreatePublishEngine();
using (pe)
pe.BeginPlot(null, null);
// We'll be plotting a single document
pe.BeginDocument(pi, Active.Document.Name, null, 1, true, outputFilename);
PlotPageInfo ppi = new PlotPageInfo();
pe.BeginPage(ppi, pi, true, null);
pe.BeginGenerateGraphics(null);
pe.EndGenerateGraphics(null);
// Finish the sheet
pe.EndPage(null);
// Finish the document
pe.EndDocument(null);
pe.EndPlot(null);
ret = true;
else
ret = false;
return ret;
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
