Set document variable (in memory)
ym.56789
ym.56789
Hi, I have a number of files where the variable VISRETAIN as to be updated.
I would like to do so by loading the document in memory.
I have the following code:
Dim myDB As New Database(False, True)
myDB.ReadDwgFile(file, FileOpenMode.OpenForReadAndAllShare, False, "")
Is there a way to set drawing variables from the database? And if I must get a document object, is there a way to load a document in memory?
(I found that I can set variables within a document as follows: acadDocument.Setvariable("DIMASZ",1.5).
_gile
The Database class exposes a Visretain property. you can simply do:
myDB.VisRetain = 0
or:
myDB.VisRetain = 1
Gilles Chanteau
GileCAD
GitHub
ym.56789
Thank you very much for your answer - I see I can access all other document variables in this manner as well.
Can you perhaps help me further though? I don't seem to know how to save the variable: (here's my code)
myDB.ReadDwgFile(file, FileOpenMode.OpenForReadAndWriteNoShare, False, "")
Using myTrans As Transaction = myDB.TransactionManager.StartTransaction
myDB.Visretain = 0
myTrans.Commit()
End Using
The code runs with no errors, but when I open up the file VISRETAIN is still at 1. (Additionally in the file properties the date modified property shows the file was not modified recently.)
_gile
You have to save your database before disposing it.
Using myDB As New Database(False, True)
        myDB.Visretain = 0
        myTrans.Commit()
    End Using
    myDB.SaveAs(file, DwgVersion.Current)
End Using
Gilles Chanteau
GileCAD
GitHub
ym.56789
Thanks a lot!
