how to turn on "Plot with plot styles" in the code?
wesbird
wesbird
hi, I tried to print in black and white. I found, if "Plot with plot styles" is checked, then it's black and white. but if it's not checked, then the output still colored. how I can make sure "Plot with plot styles" is checked in my code.
here is my code
private static bool PublishFile(string outputFilename,
	string mediaName,
	string styleSheetName,
	string plotDeviceName,
	int intStdScaleType)
	PlotRotation myPlotRotation = PlotRotation.Degrees000;
	bool ret = false;
	BlockTableRecord btr = Active.Database.CurrentSpaceId.GetObject<BlockTableRecord>();
	Layout lo = btr.LayoutId.GetObject<Layout>();
	// We need a PlotInfo object linked to the layout
	PlotInfo pi = new PlotInfo();
	pi.Layout = btr.LayoutId;
	// We need a PlotSettings object based on the layout settings which we then customize
	PlotSettings ps = new PlotSettings(lo.ModelType);
	ps.CopyFrom(lo);
	// The PlotSettingsValidator helps create a valid PlotSettings object
	PlotSettingsValidator psv = PlotSettingsValidator.Current;
	// We'll plot the extents, centered and scaled to fit
	psv.SetPlotType(ps, Autodesk.AutoCAD.DatabaseServices.PlotType.Extents);
	psv.SetUseStandardScale(ps, true);
	//psv.SetStdScaleType(ps, StdScaleType.ScaleToFit);
	StdScaleType myStdScaleType = StdScaleType.ScaleToFit;
	if (Enum.IsDefined(typeof(StdScaleType), intStdScaleType))
		myStdScaleType = (StdScaleType)intStdScaleType;
	psv.SetStdScaleType(ps, myStdScaleType);
	try
		//psv.SetPlotCentered(ps, true);
		psv.SetPlotCentered(ps, false);
		psv.SetPlotOrigin(ps, new Point2d(0, 0));
		//psv.SetPlotPaperUnits(ps, PlotPaperUnit.Inches);
		//psv.SetPlotPaperUnits(ps, PlotPaperUnit.Millimeters);
		psv.SetPlotRotation(ps, myPlotRotation);
	catch (System.Exception caught)
		throw;
	// print in color or black/white
	psv.RefreshLists(ps);
	psv.SetCurrentStyleSheet(ps, styleSheetName);
	psv.SetPlotConfigurationName(ps, plotDeviceName, mediaName);
	// We need to link the PlotInfo to the PlotSettings and then validate it
	pi.OverrideSettings = ps;
	PlotInfoValidator piv = new PlotInfoValidator();
	piv.MediaMatchingPolicy = MatchingPolicy.MatchEnabled;
	piv.Validate(pi);
	// A PlotEngine does the actual plotting (can also create one for Preview)
	if (PlotFactory.ProcessPlotState == ProcessPlotState.NotPlotting)
		PlotEngine pe = PlotFactory.CreatePublishEngine();
		using (pe)
			pe.BeginPlot(null, null);
			// We'll be plotting a single document
			pe.BeginDocument(pi, Active.Document.Name, null, 1, true, outputFilename);
			PlotPageInfo ppi = new PlotPageInfo();
			pe.BeginPage(ppi, pi, true, null);
			pe.BeginGenerateGraphics(null);
			pe.EndGenerateGraphics(null);
			// Finish the sheet
			pe.EndPage(null);
			// Finish the document
			pe.EndDocument(null);
			pe.EndPlot(null);
		ret = true;
	else
		ret = false;
	return ret;
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
norman.yuan
psv.SetCurrentStyleSheet(xxxx, "[A Mono PlotStyle Sheet].ctb");
You may want to first call PlotSettingValidator.GetPlotStyleSheetList() to see if the desired "mono-color" style sheet is available or not.
Norman Yuan
Drive CAD With Code
hippe013
Ensure that your layout (lo) is opened for write.
lo.PlotPlotStyles = True;
