I draw a print in AutoCAD with 200 circles containing 200 Multileaders with text "XXX To A" where XXX is actually distance to Datum A. I know the design will be fixed but I will need to update these 200 x "XXX" every time the customer comes up with something new. My idea is to create a datagridview table or direct import Excel file to update these 200 x "XXX".
My approach:
1. Create a data table as user input or using Excel as input --> contains 200 x "XXX" ----> this is not the issue
2. Create 200 x Multileaders with text "XXX", then associate their text property with some ID ---> like txtS001, txtS002, txtS003..txtS200.. and do
txtS001.Text = (string)new_value;
3. Loop through the datagridview or Excel file to make the update
How can I associate an object's property/attributes to manageable ID as reference? And if there is any sample code to make the update
Step 1: create a table in your acad drawing. I use a table with 2 columns: first col is the description of the field, second column is the actual field.
step 2: assign each dimension to a cell in the table (from col 2). Use field- formula, then click on the table cell you want to assign to.
Now if you manually change the value in the table and do a refresh, dimension will get updated with value from table.
Step 3:
The code is in vb.net but you can easily convert it to c#
Value() is an array of values from excel or where ever you have the 200 values
Public Sub PopulateCalcDataTable(ByVal LayoutName As String, ByVal Value() As String)
Dim acLayouts As AcadLayouts
Dim acEntity As AcadEntity
AcadDrawing.ActiveSpace = AcActiveSpace.acPaperSpace
acLayouts = AcadDrawing.Layouts
AcadDrawing.ActiveLayout = AcadDrawing.Layouts.Item(LayoutName)
For Each acEntity In AcadDrawing.PaperSpace
If acEntity.ObjectName = "AcDbTable" AndAlso
acEntity.GetText(0, 0) = "Calc Data" Then
For index As Integer = LBound(Value) To UBound(Value)
If Value(index) = "--" Or Value(index) = "--'" Then
Value(index) = "0"
acEntity.SetText(index + 1, 1, Value(index))
Next
Next
End Sub
Thanks, I asked another question in normal AutoCAD forum and I got the answer, the List will return the HandleID as I can use to point to the object
@Anonymous wrote:Step 1: create a table in your acad drawing. I use a table with 2 columns: first col is the description of the field, second column is the actual field.
Step 3:
Value(index) = "0"
Next
NextEnd Sub
Just don't insert/delete columns or rows to the left of/above the referenced cell in the table afterward.
It seems someone didn't think that one out, because references to cells should be able to survive those operations.
