.NET
How to create a region
3 REPLIES 3
mecoman6GF27
226 Views, 3 Replies
Hi everyone.
I'm trying to create a region from a simple circle but when I type "myRegionColl = Region.CreateFromCurves(acDBObjColl)" I get this error: "CreateFromCurves is not a member of Region". What do you think is the problem?
Thanks bye.
3 REPLIES 3
_gile
in reply to: mecoman6GF27
What is the type of Region in your code? It should be: Autodesk.AutoCAD.DatabaseServices.Region.
Gilles Chanteau
GileCAD
GitHub
You are probably not using the correct Region type {System.Drawing.Region maybe?) , but you really should post your code so that others can identify the exact cause of the problem.
Don't expect those reading your question to guess what your code is doing.
mecoman6GF27
Hi.
The solution was the one proposed by _gile.
Thank you very much, bye.
Forma Design Contest
AutoCAD Beta
