How to check if entity is part of "Working Set"?
I am trying to determine if an entity is part of the "Working Set". In other words, belongs to a Block or Xref that is currently being edited in-place.
Does the API have ability to check this?
Jon
ActivistInvestor
Jon
I think you're looking for the WorkSetHas() method of the LongTransaction class.
You get an instance of that class from the LongTransactionManager's CurrentLongTransactionFor() method.
This does look like what I need, but having trouble trying to reference it. I am obviously missing something here....
OR
ActivistInvestor
OR
Here's an extension method for the Document class, that tells if the entity with the given ObjectId is in the working set:
namespace Autodesk.AutoCAD.ApplicationServices
   public static class MyDocumentExtensions
      public static bool WorkSetHas(this Document doc, ObjectId id, bool includingErased = true)
         ObjectId id = Application.LongTransactionManager.CurrentLongTransactionFor(doc);
         if(!id.IsNull)
            using(var trans = new ReadOnlyTransaction())
               LongTransaction ltr = (LongTransaction) trans.GetObject(id, OpenMode.ForRead);
               return ltr.WorkSetHas(entityId, includingErased);
         return false;
namespace Autodesk.AutoCAD.DatabaseServices
   public class ReadOnlyTransaction : OpenCloseTransaction
      protected override void DeleteUnmanagedObject()
         Commit();
         base.DeleteUnmanagedObject();
      public override void Abort()
         Commit();
Thanks, that helped!
I was missing Application before LongTransactionManager
Dim oid As ObjectId = Autodesk.AutoCAD.ApplicationServices.Application.LongTransactionManager.CurrentLongTransactionFor(DocumentManager.MdiActiveDocument)
ActivistInvestor
Whoops.
I wrote that one quickly and without testing it.
In case anyone is interested, here is a working version:
      public static bool WorkSetHas(this Document doc, ObjectId entityId, bool includingErased = true)
         // Assert.IsNotNull(doc, "doc");
         if(!id.IsNull)
         return false;
         Commit();
         Commit();
