.NET
How to change the handle id
1 REPLY 1
718 Views, 1 Reply
Hello Everyone,
Problem Statement:
How to create a handle for lines.
Description:
I have a polyline i need to convert into lines .So what i did was , explode the polyline.
It's converting into lines.[By using the handle Id i am highlighting the Lines].
But when i am exploding the polyline lines handel Id giving "0".So i need to change the handle Id.
So i  can easily highlight the lines based on handle.
Is there any way to change the handle ID?
Can anyone suggest me how to change the handle Ids?
1 REPLY 1
Alexander.Rivilis
Handle is "0" only if object/entity not added to Database! There is no API which can change Handle. You can only swap Handle between  two object/entity.
P.S.: You select wrong forum. This forum only for ObjectARX/C++. Right forum for your question is:  >>> .NET <<<
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Forma Design Contest
