.NET
how to change block name
4 REPLIES 4
imagination_s
808 Views, 4 Replies
Hellow Everyone
I am trying to change a block name.
First a clone the block and then i want to change the block name from DOT to DOT2
Here is my part of code.I know is something with block record and new block record
 Dim acBlkTbl As BlockTable
        acBlkTbl = myT.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
        Dim acBlkTblRec As BlockTableRecord
        Dim blkname As String = "DOT2"
        acBlkTblRec = myT.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
        acBlkTblRec.Name = blkname
        acBlkTbl.UpgradeOpen()
I know that something is wrong.
Please Help.Thankyou for your help
4 REPLIES 4
SENL1362
in reply to: imagination_s
You're changing the Block==ModelSpace. I'm pretty sure you are going to regret that. 🙂
I'll recommend(not tested):
acBlkTblRec = myT.GetObject(acBlkTbl("DOT"), OpenMode.ForWrite)
SENL1362
in reply to: SENL1362
or in C#:
        [CommandMethod("TestRenameBlock")]
        public void TestRenameBlock()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            string oldBlockName = "DOT";
            string newBlockName = "DOT2";
            try
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                    if (!bt.Has(oldBlockName))
                        throw new System.Exception(string.Format("Error: TestRenameBlock: Old Block not found: {0}", oldBlockName));
                    if (bt.Has(newBlockName))
                        throw new System.Exception(string.Format("Error: TestRenameBlock: New Block already exists: {0}", newBlockName));
                    BlockTableRecord oldBlock = (BlockTableRecord)tr.GetObject(bt[oldBlockName], OpenMode.ForRead);
                    oldBlock.UpgradeOpen();
                    oldBlock.Name = newBlockName;
                    tr.Commit();
            catch (System.Exception ex)
                ed.WriteMessage(ex.Message);
imagination_s
Thankyou so much for your help 🙂
Nice code.It works
Apreciated
Thankyou again
SENL1362
My pleasure.
Forma Design Contest
