.NET
How to add new objects to a exist blocktablerecord?
2 REPLIES 2
swaywood
246 Views, 2 Replies
Hi everyone,
I want to clear all objects in an existing blocktablerecord,
add several new objects, and redefine the block.
I wrote some code according to my own ideas,
but the new block generated is an empty block.
Please help me find out what the problem is.
Thank you
    public static ObjectId AddBlockTableRecord(this Database db, string blockName, Point3d Position, params ObjectId[] ids)
      BlockTable bt = (BlockTable)db.BlockTableId.GetObject(OpenMode.ForRead);
      BlockTableRecord btr;
      using (Transaction trans = db.TransactionManager.StartTransaction())
        if (!bt.Has(blockName))
          btr = new BlockTableRecord();
          btr.Name = blockName;
        else
          btr = (BlockTableRecord)trans.GetObject(bt[blockName], OpenMode.ForWrite);
          foreach (ObjectId id in btr)
            Entity ent = (Entity)trans.GetObject(id, OpenMode.ForWrite);
            ent.Erase();
        btr.Explodable = true;
        btr.Origin = Position;
        foreach (ObjectId id in ids)
          Entity ent = id.Clone<Entity>();
          if (ent.IsNewObject)
            btr.AppendEntity(ent);
        bt.UpgradeOpen();
          bt.Add(btr);
          db.TransactionManager.AddNewlyCreatedDBObject(btr, true);
        else
          if (!id.IsNull)
            id.GetObject(OpenMode.ForWrite).Erase(true);
        btr.DowngradeOpen();
        bt.DowngradeOpen();
        trans.Commit();
      return bt[blockName];
2 REPLIES 2
_gile
in reply to: swaywood
You should use the Database.DeepCloneObject method instead of the RXObjectClone one.
IMO, it's also better to move the entities within the block definition instead of defining the BlockTableRecord.Origin property.
And also, you should either strart a new transaction or use the TopTransaction, but not mix both.
            ObjectId btrId;
                var bt = (BlockTable)trans.GetObject(db.BlockTableId, OpenMode.ForRead);
                    trans.GetObject(db.BlockTableId, OpenMode.ForWrite);
                    btrId = bt.Add(btr);
                    trans.AddNewlyCreatedDBObject(btr, true);
                else
                    btrId = bt[blockName];
                    btr = (BlockTableRecord)trans.GetObject(btrId, OpenMode.ForWrite);
                        trans.GetObject(id, OpenMode.ForWrite).Erase();
                var oIds = new ObjectIdCollection(ids);
                var mapping = new IdMapping();
                db.DeepCloneObjects(oIds, btrId, mapping, false);
                var displacement = Matrix3d.Displacement(Position.GetAsVector().Negate());
                foreach (IdPair pair in mapping)
                    if (pair.IsCloned && pair.IsPrimary)
                        var entity = (Entity)trans.GetObject(pair.Value, OpenMode.ForWrite);
                        entity.TransformBy(displacement);
                    if (!id.IsNull)
                trans.Commit();
            return btrId;
Gilles Chanteau
GileCAD
GitHub
swaywood
in reply to: _gile
thanks Giles
Forma Design Contest
