.NET
How can I use 'Project Objects To Profile View' with C#?
2 REPLIES 2
IgorRamosTPF
166 Views, 2 Replies
How can I use the 'Project Objects To Profile View' command using the Civil 3D API, with C#?
I have several CogoPoints, and I want to project those in a selected Profile View, and set the label style for different groups.
2 REPLIES 2
hosneyalaa
in reply to: IgorRamosTPF
refer to the Civil 3D .NET API Ref document, ProfileProjection class has only few properties exposed, create() is not exposed for public usage
but can you see this
// https://forums.autodesk.com/t5/civil-3d-customization/vba-project-object-to-profile-view/m-p/5953577
Set PVObj = ThisDrawing.HandleToObject(PVHandle(i))
PVObj.GetBoundingBox Varmin, VarMax
ZoomWindow Varmin, VarMax
ThisDrawing.SendCommand "_AECCPROJECTOBJECTSTOPROF" & vbCr & "Previous" & vbCr & vbCr & Varmin(0) & "," & VarMax(1) & vbCr
IgorRamosTPF
Thanks for the suggestion, I was having trouble using the Editor Command because the last parameter, the one for selecting the Styles, wasn't working. But I solved it this way:
the selection sets were created using SelectionSet.FromObjectIds.
In this way, it still shows this window, but no problem:
Forma Design Contest
AutoCAD Beta
