.NET
HELP!!! Unable to load .dll
6 REPLIES 6
songmaverick
599 Views, 6 Replies
I would like to learn C# to code some function in order to simply the my drawing work..
My IDE : Visual Studio
AUTUCAD 2020
I use Class Library (.NET Framework) templates to create a project and build solution.
I add accoremgd,  acdbmgd,  acmgd in Reference.
I get the .dll from /bin/Debug/.dll and type 'netload' in CAD 2020 to load the .dll file.
But I get this result as follows
I repeat these on my colleague's CAD2020, it is OK..
Could anyone tell me what is wrong with my computer?
Thank!!!
6 REPLIES 6
kdub_nz
in reply to: songmaverick
Please Clarify.
Is the dll that doesn't load on your machine loading on your associated machine
or
are you rebuilding on your associates machine and loading it there ?
By any chance are you ignoring a Trusted Location warning ??
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
songmaverick
in reply to: kdub_nz
Thanks for your reply!!
I do not build the solution on my colleague's computer and I use the same .dll to netload in cad
I am sure no  Trusted  warning appears .
I type 'netload' and choose the .dll and it says unable to .....
there is a warning appearing in my colleagues' CAD .
My colleague's warning is below
I am confused that there is no warning in my CAD!!
Tags (1)
songmaverick
Option -> System ->Security Options
change the Security Level from High to Medium
songmaverick
Thanks for your reply , which reminds me of changing the Security Level
I could netload .dll
kdub_nz
I had a suspicion it was a 'trust' issue becaue I've seen the wording of the message when cancelling the load from the Security dialog.
Glad it's working.
songmaverick
Thank you very much
I set high security level before . So the warning would not come out .
Your reply reminds me of this ..
Thank you again!!
Forma Design Contest
