.NET
Getting Vertices Between two Points of a Polyline or Line in a Form of PointColl
4 REPLIES 4
538 Views, 4 Replies
Hi Guys
Could you Please help any one on the subjected request. As i Need to Get vertices Between Two user Selected Points in a polyline.
The Return Type I need it in the Form of Point3dCollection.
Alex Andrews
4 REPLIES 4
_gile
You can try the following code.
It assumes point1 and point2 are defined in WCS coordinates and the current view is Top.
For a solution working whatever the context, you can read the discussion I had with @ActivistInvestor about getting a point on curve in this post.
        private Point3dCollection GetPolylineVerticesBetweenPoints(Polyline pline, Point3d point1, Point3d point2)
            double param1 = pline.GetParameterAtPoint(pline.GetClosestPointTo(point1, false));
            double param2 = pline.GetParameterAtPoint(pline.GetClosestPointTo(point2, false));
            double startParam = Math.Min(param1, param2);
            double endParam = Math.Max(param1, param2);
            int startIndex = (int)startParam;
            if (startIndex != startParam) startIndex++;
            int endIndex = (int)endParam;
            if (endIndex == endParam) endIndex++;
            var vertices = new Point3dCollection();
            for (int i = startIndex; i < endIndex; i++)
                vertices.Add(pline.GetPoint3dAt(i));
            return vertices;
Gilles Chanteau
GileCAD
GitHub
_gile
in reply to: _gile
Oopss...
There's a mistake in the upper code.
Try this one instead.
            int endIndex = (int)endParam + 1;
            return vertices;
Gilles Chanteau
GileCAD
GitHub
in reply to: _gile
Hi Gilles, Thanks for Helping me.
How ever I have few more issues, When handling with Different Geometries.
As "pline.GetPoint3dAt(i)" method is ssupportable for only Polylines; Incase of Lines, Arc, Spline, Its Can't be found... Could you Please Look into this?
Regards
Alex.
ActivistInvestor
Regards
Alex.
You didn't ask for that.
Read the subject line of your post.  It says Vertices between two Points of a Polyline or Line.
Lines, arcs, splines, and other curves aside from polylines do not have vertices, so your question makes no sense from the outset.
Forma Design Contest
AutoCAD Beta
