.NET
Get result/response from console executed by document.SendStringToExecute
2 REPLIES 2
nwbos
268 Views, 2 Replies
I'm currently converting an Lisp project to C# .NET.
Not al functionalities wil be merged at once. For this reason i still use some Autolisp commands in my C# implementation.
I have the following code to execute some Autolisp command. This command returns a string printed in the Autocad console.
public void GetCoordinateSystem()
   var document = Application.DocumentManager.MdiActiveDocument;
   var lispCommand = "(some_lisp_command) ";
   document.SendStringToExecute(lispCommand, false, false, false);
 My question is how can i catch te string that the Autolisp command returns in the console.
Labels (3)
2 REPLIES 2
nwbos
in reply to: nwbos
I have found some working
    var document = GetActiveDocument();
    string someLispCommandResult = "(some_lisp_command) ";
    document.SendStringToExecute(someLispCommandResult, false, false, false);
    System.Collections.Generic.List<string> result = Autodesk.AutoCAD.Internal.Utils.GetLastCommandLines(3, false);
    Application.ShowAlertDialog(result[2]);
this feels a bit hacky can this be implemented in a more proper way?
hippe013
in reply to: nwbos
Keep in mind that SendStringToExecute runs asynchronously.
Forma Design Contest
