Hi folks
It seems that the autocad .net forums are not displaying correctly. it is not showing in Firefox, nor in Chrome, nor in MS Edge (i.e. the new Internet Explorer). Any advice much appreciated.
See image attached.
Solved by BKSpurgeon. Go to Solution.
Solved by Alexander.Rivilis. Go to Solution.
It seems working fine at my end. I tried in couple of machines.. sorry not sure about the issue.
Do you use Kaspersky Anti-Virus? If yes - you have to disable checking https-traffic for forums.autodesk.com (or globally).
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
You were 100% correct Alexander.
For future readers, here's how I solved the issue:
First Steps in Kaspersky
Change settings to: "Do not Scan"
I hope that helps!
