.NET
Forum Not Displaying Properly
3 REPLIES 3
BKSpurgeon
987 Views, 3 Replies
Hi folks
It seems that the autocad .net forums are not displaying correctly. it is not showing in Firefox, nor in Chrome, nor in MS Edge (i.e. the new Internet Explorer). Any advice much appreciated.
See image attached.
3 REPLIES 3
It seems working fine at my end. I tried in couple of machines.. sorry not sure about the issue.
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
@BKSpurgeon
Do you use Kaspersky Anti-Virus? If yes - you have to disable checking https-traffic for forums.autodesk.com (or globally).
Facebook | Twitter | LinkedIn
Expert Elite Member
You were 100% correct Alexander.
For future readers, here's how I solved the issue:
  1.  You can as Rivilis suggested - simply add autodesk sites (so that they are excepted from scanning), or you could go one step further as I did
  2. Disable encrypted scanning. If you're using TCP/IP HTTPS i don't see much benefit, especially if the anti-virus software does a poor job of handling your security (according to what I read online). So i've done the following to disable it. WARNING: If you suffer any security problems by doing this then do not blame me or hold me responsible:
First Steps in KasperskyFirst Steps in KasperskyChange settings to: "Do not Scan"Change settings to: "Do not Scan"
I hope that helps!
Forma Design Contest
AutoCAD Beta
