.NET
Flip State Names
2 REPLIES 2
BrentBurgess1980
874 Views, 2 Replies
Flip State Names
Hi All,
DynamicBlockReferencePropertyCollection dynPropColl = bref.DynamicBlockReferencePropertyCollection;
                        foreach(DynamicBlockReferenceProperty prop in dynPropColl)
                            object[] values = prop.GetAllowedValues();
The allowable values you can select from are 1 or 0 (makes sense), but is there any exposed/other way to show the "displayed" allowed values that are shown in the properties palette? My initial thought is that there isn't anything, given the properties in DynamicBlockReferenceProperty. Happy to be proven wrong though.
Cheers,
Brent
2 REPLIES 2
Using the API DynamicBlockReferencePropertyCollection to access list of flip states is the only recommended way to access flip state names.
There is method which is undocumented or unsupported to access the visibility state of dynamic blocks. Similarly, flip states can be accessed as shown below(modified code from the blog):
http://adndevblog.typepad.com/autocad/2012/05/accessing-visible-entities-in-a-dynamic-block.html
(Please note, it is not recommended to extract information from extension dictionary ACAD_ENCHANCEDBLOCK and API used in this implementation may change with out notice and hence is not supported)
[CommandMethod("DynablockFlipStates")]
public void DynablockFlipStates()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    Editor ed = doc.Editor;
    PromptResult pr = ed.GetString("\nEnter block name: ");
    if (pr.Status != PromptStatus.OK)
        return;
    using (Transaction Tx = db.TransactionManager.StartTransaction())
        BlockTable bt = Tx.GetObject(
            db.BlockTableId,
            OpenMode.ForRead) as BlockTable;
        if (!bt.Has(pr.StringResult))
            ed.WriteMessage("\nBlock doesn't exist :(");
            return;
        BlockTableRecord btr = Tx.GetObject(
            bt[pr.StringResult],
            OpenMode.ForRead)
                as BlockTableRecord;
        if (!btr.IsDynamicBlock)
            ed.WriteMessage("\nNot a dynamic block :(");
            return;
        if (btr.ExtensionDictionary == null)
            ed.WriteMessage("\nNo ExtensionDictionary :(");
            return;
        DBDictionary dico = Tx.GetObject(
            btr.ExtensionDictionary,
            OpenMode.ForRead)
                as DBDictionary;
        if (!dico.Contains("ACAD_ENHANCEDBLOCK"))
            ed.WriteMessage(
                "\nACAD_ENHANCEDBLOCK Entry not found :(");
            return;
        ObjectId graphId = dico.GetAt("ACAD_ENHANCEDBLOCK");
        System.Collections.Generic.List<object> parameterIds =
            acdbEntGetObjects(graphId, 360);
        foreach (object parameterId in parameterIds)
            ObjectId id = (ObjectId)parameterId;
            if (id.ObjectClass.Name ==
                "AcDbBlockFlipParameter")
                System.Collections.Generic.List<TypedValue>
                    flipParam = acdbEntGetTypedVals(id);
                System.Collections.Generic.List<TypedValue>.Enumerator enumerator =
                    flipParam.GetEnumerator();
                while (enumerator.MoveNext())
                    ed.WriteMessage("\n    - " + enumerator.Current.TypeCode.ToString() + ",");
                    try
                        string str = (string)enumerator.Current.Value;
                        ed.WriteMessage("\n . string value : " + str);
                    catch
                break;
        Tx.Commit();
public struct ads_name
    public IntPtr a;
    public IntPtr b;
[DllImport("accore.dll", CallingConvention = CallingConvention.Cdecl)]
static extern IntPtr acdbEntGet(long[] objName);
[DllImport("acdb23.dll", CallingConvention = CallingConvention.Cdecl, EntryPoint =
            "?acdbGetAdsName@@YA?AW4ErrorStatus@Acad@@AEAY01_JVAcDbObjectId@@@Z")]
static extern ErrorStatus acdbGetAdsName64(long[] objName, ObjectId id);
private System.Collections.Generic.List<object>
    acdbEntGetObjects(ObjectId id, short dxfcode)
    System.Collections.Generic.List<object> result =
        new System.Collections.Generic.List<object>();
    long[] name = new long[] { 0, 0 };
    ErrorStatus res = acdbGetAdsName64(name, id);
    ResultBuffer rb = new ResultBuffer();
    Autodesk.AutoCAD.Runtime.Interop.AttachUnmanagedObject(
        rb, acdbEntGet(name), true);
    ResultBufferEnumerator iter = rb.GetEnumerator();
    while (iter.MoveNext())
        TypedValue typedValue = (TypedValue)iter.Current;
        if (typedValue.TypeCode == dxfcode)
            result.Add(typedValue.Value);
    return result;
private System.Collections.Generic.List<TypedValue>
    acdbEntGetTypedVals(ObjectId id)
    System.Collections.Generic.List<TypedValue> result =
        new System.Collections.Generic.List<TypedValue>();
        result.Add((TypedValue)iter.Current);
    return result;
Thanks for the information. Will take advice on board re support etc
Forma Design Contest
AutoCAD Beta
