.NET
Difference between acedCmd and acedPostCommand?
6 REPLIES 6
1226 Views, 6 Replies
Just out of curiosity, what's the difference between acedPostCommand and acedCmd?
6 REPLIES 6
Alexander.Rivilis
This is a completely different functions:
1) The first asynchronous - the second synchronous
2) The first takes as a parameter only string - the second strings, doubles, array of doubles, etc.
3) The first requires the final " " or "\n" - the second does not.
But both functions require PInvoke in .NET 🙂
Facebook | Twitter | LinkedIn
Expert Elite Member
How does this vary from Editor.Command()? Is it basically a wrapped implementation of acedCmd?
Alexander.Rivilis
acedCmd is the same as Editor.Command()
acedPostCommand is similar (but not the same) as Document.SendStringToExecute()
Expert Elite Member
Thanks for the information. Very good info.
in reply to: Alexander.Rivilis
Sorry for the additional reply. I was answering from out of town previously. What is the major difference between acedPostCommand() and SendStringToExecute() then?
Alexander.Rivilis
acedPostCommand send command only to active document (Application.DocumentManager.MdiActiveDocument)
Document.SendStringToExecute() send command to any opened document.
More on this can probably tell only Autodesk specialists.
Expert Elite Member
AutoCAD Inside the Factory
