Reg. Extract attributes without opening Drawing file
Message 1 of 8
Hi everyone,
I want to extract the attributes from the drawing file without opening drawing file.
Is there any way to do it ?
If it is possible then which API will be work Automation(ActiveX API) or Customization(.NET API) ?
Replies (7)
Message 2 of 8
Are you asking how to extract block attributes without opening drawing file? Or drawing properties? Need clarification.
Message 3 of 8
owenwengerd
Your question sounds like "Can I read a book without opening it?" You should be more precise about what you mean by "attributes" and "opening". You must open a file in the operating system sense to read data from it, so perhaps you meant "without opening the drawing file in the AutoCAD editor".
Owen Wengerd
ManuSoft
Message 4 of 8
SENL1362
Or did he meant without showing in the AutoCAD editor.
Because of the ActiveX hint he probably meant extracting out of process without AutoCAD visible.
Message 5 of 8
Dale.Bartlett
I think the request is to batch process a collection of drawings and extract block attributes.
Refer here for code to open drawings:
http://forums.autodesk.com/t5/net/readdwgfile-side-database-correct-useage/td-p/5444657
And this may help for returning attributes and other block information:
<code>
// return csv string to write out to file
// specifically block name, attribute value and insert point (x,y,z)
public static string GetBlockInfo(Database pDb, Entity pEnt, string pstrAttTag)
string lstrReturnValue = string.Empty;
using (Transaction tr = pDb.TransactionManager.StartTransaction())
if (pEnt.GetType() == typeof(BlockReference))
// cast entity to a block reference
BlockReference br = pEnt as BlockReference;
// if successful, continue
if (br != null)
BlockTableRecord btr = tr.GetObject(br.BlockTableRecord, OpenMode.ForRead, false) as BlockTableRecord;
// get block name
string lstrBlockName = btr.Name;
// get attribute
string lstrAttValue = string.Empty;
Autodesk.AutoCAD.DatabaseServices.AttributeCollection attcol = br.AttributeCollection;
foreach (ObjectId attId in attcol)
AttributeReference attRef = tr.GetObject(attId, OpenMode.ForWrite) as AttributeReference;
if (pstrAttTag.Equals(attRef.Tag))
lstrAttValue = attRef.TextString;
// get insert point
Point3d lpntInsertPoint = br.Position;
// csv version
string lstrInsertPoint = lpntInsertPoint.X.ToString() + "," + lpntInsertPoint.Y.ToString() + "," + lpntInsertPoint.Z.ToString();
// assemble return string
lstrReturnValue = lstrInsertPoint + "," + lstrBlockName + "," + lstrAttValue;
tr.Commit();
return lstrReturnValue;
</code>
Dale
______________
Yes, I'm Satoshi.
Message 6 of 8
We need both.
Message 7 of 8
We also want to read drawing file without installing AutoCAD in machine.
Is it possible ?
Message 8 of 8
Dale.Bartlett
If you wish to access a dwg database you will need either AutoCAD installed and licenced, or a licence for RealDWG. Dale
______________
Yes, I'm Satoshi.
