.NET
Detach XRefs
2 REPLIES 2
gwhitcherQ98HZ
181 Views, 2 Replies
Detach XRefs
I have been trying to detach the Xrefs in a list of drawings and had no success.  I open each one then I use this code. It does hit the db.detachXref(oid) line. No errors but does not detach it.
 doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
                ed = doc.Editor
                db = doc.Database
                Using lk As DocumentLock = doc.LockDocument()
                    Using tr As Transaction = db.TransactionManager.StartTransaction()
                        Dim bt As BlockTable = TryCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
                        For Each oid As ObjectId In bt
                            Dim btr As BlockTableRecord = CType(tr.GetObject(oid, OpenMode.ForRead), BlockTableRecord)
                            If btr.IsFromExternalReference Then
                                db.DetachXref(oid)
                            End If
                        Next
                    End Using
                End Using
2 REPLIES 2
fieldguy
in reply to: gwhitcherQ98HZ
you are missing tr.Commit() before end using
How did I miss that! Thank you!
Forma Design Contest
AutoCAD Beta
