.NET
Debugging in 2017
2 REPLIES 2
SRSDS
2411 Views, 2 Replies
Debugging in 2017
I'm getting an eKeyNotFound error when using my app in AutoCAD 2017 but, because I can't debug it, I can't work out the problem.
I have VS2013.
I've tried these two methods to get debugging happening but they don't want to work.
  1. Turn on “Use Managed Compatibility Mode” via Tools –> Options –> Debugging.
  2. Turn on “Enable native code debugging” from Project –> Properties –> Debug.
Are people available that I could pay to remotely jump on my computer via TeamViewer to help solve the problem? I have a few questions and it would be great if someone could explain them to me all in one hit..
2 REPLIES 2
norman.yuan
in reply to: SRSDS
I have only heard that there was .NET debugging issue with AutoCAD 2017 and Visual Studio 2015, which has been addressed by AutoCAD 2017 SP1. See link here:
http://adndevblog.typepad.com/autocad/2016/07/autocad-2017-sp1-and-net-debugging.html
Since you use VS2013, I am not sure AutoCAD2017 SP1 would be helpful or not, but you could give it a try.
Norman Yuan
Drive CAD With Code
SRSDS
in reply to: norman.yuan
Norman, thankyou!
I was worried there might not be a fix if I could't debug.
It does work with VS2013 and just about to search for the problem.
You've made my morning.
Technology Administrators
