.NET
Created Polyline3d from corridor's applied subassembly is not planar
2 REPLIES 2
michal_hcz
211 Views, 2 Replies
I wanted to create a lofted solid3d from polyline3ds which I got from shape points in an applied subassembly in a corridor. But some of them are not planar. So I ortho-projected shape points onto a plane created from corridor frequency but this didn't work either even though point coordinates were slightly modified.
Tested on Civil 24 and 25.
But when I use autocad command LOFT solid is created.
Any idea how to deal with that non-planar 3d polylines?
Thanks for any recommendations.
Corridor created along Y axis but some of polylines are still not planar.
Corridor Corridor = corrId.GetObject(OpenMode.ForRead) as Corridor;
	foreach (Baseline bl in Corridor.Baselines)
		foreach (BaselineRegion reg in bl.BaselineRegions)
			foreach (double station in reg.SortedStations())
				AppliedAssembly appliedAssembly = reg.AppliedAssemblies.GetItemAt(station);
				foreach (var subass in appliedAssembly.GetAppliedSubassemblies())
					foreach (CalculatedShape cShape in subass.Shapes)
						foreach (string shapeCode in cShape.CorridorCodes)
							foreach (CalculatedLink cLink in cShape.CalculatedLinks)
								foreach (CalculatedPoint cPoint in cLink.CalculatedPoints)
									// cPoint.XYZ <-- points for polylines
internal void CreatePolyline3d(List<Point3d> points, Transaction tr)
	if (points.Count < 3) return;
	Polyline3d Polyline3d = new Polyline3d();
	Polyline3d.ColorIndex = 3;
	var bt = (BlockTable)tr.GetObject(HostApplicationServices.WorkingDatabase.BlockTableId, OpenMode.ForRead, false);
	var btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite, false);
	btr.AppendEntity(Polyline3d);
	tr.AddNewlyCreatedDBObject(Polyline3d, true);
	foreach (Point3d p in points)
		PolylineVertex3d vertex = new PolylineVertex3d(p);
		Polyline3d.AppendVertex(vertex);
		tr.AddNewlyCreatedDBObject(vertex, true);
	Polyline3d.Closed = true;
internal void CreateSolid3d(Polyline3d poly1, Polyline3d poly2, Transaction tr)
	if (poly1.IsPlanar && poly2.IsPlanar) // <-- some of them are not planar
		Solid3d s = new Solid3d();
		s.CreateLoftedSolid(new Entity[2] { poly1, poly2 }, new Entity[0], null, new LoftOptions());
		btr.AppendEntity(s);
		tr.AddNewlyCreatedDBObject(s, true);
2 REPLIES 2
hosneyalaa
in reply to: michal_hcz
michal_hcz
Thank you, using Polyline instead of Polyline3d helped.
Michal
Forma Design Contest
AutoCAD Beta
