.NET
create layer - will now show in layermanager
2 REPLIES 2
jan_tappenbeck
243 Views, 2 Replies
hi!
know i try to create a layer by vb.net - there is no mistake, but the layer will not create!
could someone help me?
regards Jan
Public Function CreateLayer(ByVal sLayerName As String, Optional LyIdxColor As Integer = 7, _
        Optional ByVal LWeight As DatabaseServices.LineWeight = DatabaseServices.LineWeight.ByLineWeightDefault, _
        Optional ByVal LyOff As Boolean = False, _
        Optional ByVal LyFrozen As Boolean = False, _
        Optional ByVal lyLock As Boolean = False, _
        Optional ByVal lyPlotable As Boolean = True, _
        Optional ByVal lyLType As String = "Continuous", _
        Optional ByVal LayDescription As String = "") As Integer
        ' ------ http://ma22-wiki-001/eblwiki/index.php?title=Acad_(Klasse_von_EBL.MapService)#CreateLayer ------
        Dim Status As Integer = -1
        '' Get the current document and database
        Dim acDoc As Autodesk.AutoCAD.ApplicationServices.Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acDoc.Database
        Dim LayerId As ObjectId
        If LyIdxColor < 1 Or LyIdxColor > 255 Then LyIdxColor = 7
        Try
            '' Start a transaction
            Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                '' Open the Layer table for read
                Dim acLyrTbl As LayerTable
                Using acDoc.LockDocument
                    acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForRead)
                    ' wenn der Layer vorhanden, dann passiert nichts
                    If acLyrTbl.Has(sLayerName) = True Then
                        Status = 0
                    Else
                        ' Layer anlegen
                        Dim ltr As New LayerTableRecord
                        ' Eigenschaften zuweisen
                        With ltr
                            .Color = Color.FromColorIndex(ColorMethod.ByAci, LyIdxColor)
                            .LineWeight = LWeight
                            .IsOff = LyOff
                            .IsFrozen = LyFrozen
                            .IsLocked = lyLock
                            .IsPlottable = lyPlotable
                            .Description = LayDescription
                            '    .LinetypeObjectId = GetLineTypeId(lyLType)
                        End With
                        acLyrTbl.UpgradeOpen()
                        LayerId = acLyrTbl.Add(ltr)
                        acTrans.AddNewlyCreatedDBObject(ltr, True)
                        '' Save the changes
                        acTrans.Commit()
                End Using 'acDoc.LockDocument
                '' Dispose of the transaction
            End Using
        Catch ex As Exception
            Dim ErrorDetail As String = "sLayerName: " & sLayerName & vbCrLf & _
                            "LyIdxColor: " & LyIdxColor.ToString & vbCrLf & _
        "LWeight: " & LWeight.ToString & vbCrLf & _
        "LyOff: " & LyOff.ToString & vbCrLf & _
        "LyFrozen: " & LyFrozen.ToString & vbCrLf & _
        "lyLock: " & lyLock.ToString & vbCrLf & _
        "lyPlotable: " & lyPlotable.ToString & vbCrLf & _
                    "lyLType: " & lyLType & vbCrLf
            If LayDescription.Length = 0 Then
                LayDescription = LayDescription & "LayDescription: nicht angegeben!" & vbCrLf
            Else
                LayDescription = LayDescription & "LayDescription: " & LayDescription & vbCrLf
            _TryReport.Show("unerwarteter Fehler in EBL.MapService > acad > SetLayerCurrent", ex.ToString)
            Status = -1
        End Try
        Return Status
    End Function
2 REPLIES 2
_gile
in reply to: jan_tappenbeck
It seems to me you don't assign any value to the Name property of the newly created LayerTableRecord.
SymbolTableRecord.Name value is used as a key in the SymbolTable.
Gilles Chanteau
GileCAD
GitHub
jan_tappenbeck
in reply to: _gile
hi !
thanks for fast help!
regards Jan
Technology Administrators
