hi!
know i try to create a layer by vb.net - there is no mistake, but the layer will not create!
could someone help me?
regards Jan
Public Function CreateLayer(ByVal sLayerName As String, Optional LyIdxColor As Integer = 7, _ Optional ByVal LWeight As DatabaseServices.LineWeight = DatabaseServices.LineWeight.ByLineWeightDefault, _ Optional ByVal LyOff As Boolean = False, _ Optional ByVal LyFrozen As Boolean = False, _ Optional ByVal lyLock As Boolean = False, _ Optional ByVal lyPlotable As Boolean = True, _ Optional ByVal lyLType As String = "Continuous", _ Optional ByVal LayDescription As String = "") As Integer ' ------ http://ma22-wiki-001/eblwiki/index.php?title=Acad_(Klasse_von_EBL.MapService)#CreateLayer ------ Dim Status As Integer = -1 '' Get the current document and database Dim acDoc As Autodesk.AutoCAD.ApplicationServices.Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database Dim LayerId As ObjectId If LyIdxColor < 1 Or LyIdxColor > 255 Then LyIdxColor = 7 Try '' Start a transaction Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() '' Open the Layer table for read Dim acLyrTbl As LayerTable Using acDoc.LockDocument acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForRead) ' wenn der Layer vorhanden, dann passiert nichts If acLyrTbl.Has(sLayerName) = True Then Status = 0 Else ' Layer anlegen Dim ltr As New LayerTableRecord ' Eigenschaften zuweisen With ltr .Color = Color.FromColorIndex(ColorMethod.ByAci, LyIdxColor) .LineWeight = LWeight .IsOff = LyOff .IsFrozen = LyFrozen .IsLocked = lyLock .IsPlottable = lyPlotable .Description = LayDescription ' .LinetypeObjectId = GetLineTypeId(lyLType) End With acLyrTbl.UpgradeOpen() LayerId = acLyrTbl.Add(ltr) acTrans.AddNewlyCreatedDBObject(ltr, True) '' Save the changes acTrans.Commit() End If End Using 'acDoc.LockDocument '' Dispose of the transaction End Using Catch ex As Exception Dim ErrorDetail As String = "sLayerName: " & sLayerName & vbCrLf & _ "LyIdxColor: " & LyIdxColor.ToString & vbCrLf & _ "LWeight: " & LWeight.ToString & vbCrLf & _ "LyOff: " & LyOff.ToString & vbCrLf & _ "LyFrozen: " & LyFrozen.ToString & vbCrLf & _ "lyLock: " & lyLock.ToString & vbCrLf & _ "lyPlotable: " & lyPlotable.ToString & vbCrLf & _ "lyLType: " & lyLType & vbCrLf If LayDescription.Length = 0 Then LayDescription = LayDescription & "LayDescription: nicht angegeben!" & vbCrLf Else LayDescription = LayDescription & "LayDescription: " & LayDescription & vbCrLf End If _TryReport.Show("unerwarteter Fehler in EBL.MapService > acad > SetLayerCurrent", ex.ToString) Status = -1 End Try Return Status End Function
