.NET
Create a temporary polyline that is removed after the Regen command
4 REPLIES 4
cadVDJ3M
377 Views, 4 Replies
My program checks several existing polylines, and I want to check all of them that don't meet some specific conditions.
I thought about duplicating the polyline with a problem with the yellow color, but it would be interesting if this duplicated polyline was temporary, and disappeared when used when the user applied the regen command.
Something similar to Autolisp's grdraw.
Thanks.
4 REPLIES 4
norman.yuan
in reply to: cadVDJ3M
In general, you could use Transient Graphics for this kind of temporary graphics. Do a search this forum/the Internet for "Transient Graphics", you would find quite some sample code.
Norman Yuan
Drive CAD With Code
hippe013
As @norman.yuan points out, using Transients would be ideal for something like this. I use transients all the time so I came up with the following classes.
Transient Base
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.GraphicsInterface
Namespace Transients
    Public MustInherit Class TransientBase
        Implements IDisposable
        Public Property Entities As New List(Of Entity)
        Public Overridable Sub SetColor(index As Integer)
            For Each ent As Entity In Entities
                ent.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(Autodesk.AutoCAD.Colors.ColorMethod.ByAci, index)
                'ent.ColorIndex = index
            Next
            UpdateTransient()
        End Sub
        Protected Friend Sub AddTransients()
            Dim ctm As TransientManager = TransientManager.CurrentTransientManager
            For Each drawable As Drawable In Entities
                ctm.AddTransient(drawable, TransientDrawingMode.Main, 128, New IntegerCollection)
            Next
        End Sub
        Protected Friend Sub RemoveTransients()
                ctm.EraseTransient(drawable, New IntegerCollection)
            Next
                ent.Dispose()
            Next
            Entities.Clear()
        End Sub
        Protected Sub UpdateTransient()
                ctm.UpdateTransient(drawable, New IntegerCollection)
            Next
        End Sub
#Region "IDisposable Support"
        Friend disposedValue As Boolean ' To detect redundant calls
        ' IDisposable
        Protected Overridable Sub Dispose(disposing As Boolean)
            If Not disposedValue Then
                If disposing Then
                    ' TODO: dispose managed state (managed objects).
                ' TODO: free unmanaged resources (unmanaged objects) and override Finalize() below.
                ' TODO: set large fields to null.
                RemoveTransients()
                    drawable.Dispose()
                Next
                Entities.Clear()
            disposedValue = True
        End Sub
        ' TODO: override Finalize() only if Dispose(disposing As Boolean) above has code to free unmanaged resources.
        'Protected Overrides Sub Finalize()
        '    ' Do not change this code.  Put cleanup code in Dispose(disposing As Boolean) above.
        '    Dispose(False)
        '    MyBase.Finalize()
        'End Sub
        ' This code added by Visual Basic to correctly implement the disposable pattern.
        Public Sub Dispose() Implements IDisposable.Dispose
            Dispose(True)
            ' TODO: uncomment the following line if Finalize() is overridden above.
            ' GC.SuppressFinalize(Me)
        End Sub
#End Region
    End Class
End Namespace
Transient that clears upon Regen
Imports Autodesk.AutoCAD.ApplicationServices
    Public Class RegenClearTransient
        Inherits TransientBase
        Private _doc As Document
        Public Sub New(entity As Entity, doc As Document)
            Me.Entities.Add(entity)
            AddTransients()
            _doc = doc
            AddHandler _doc.CommandWillStart, cmdStartHandler
        End Sub
        Private ReadOnly cmdStartHandler As CommandEventHandler = AddressOf OnCmdStart
        Private Sub OnCmdStart(sender As Object, e As CommandEventArgs)
            If e.GlobalCommandName.Contains("REGEN") Then
                Me.RemoveTransients()
                RemoveHandler _doc.CommandWillStart, cmdStartHandler
        End Sub
    End Class
End Namespace
And then an example on how to use it
Private rcTrans As Transients.RegenClearTransient 'Must have a backer variable for the transient to stay in view.
        <CommandMethod("TempPolyTransientExample")>
        Public Sub CmdTempPolyTrans()
            Dim aDoc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = aDoc.Database
            Dim ed As Editor = aDoc.Editor
            Dim opt As New PromptEntityOptions(vbCrLf + "Select Polyline: ")
            opt.SetRejectMessage(vbCrLf + "Selected entity must be a Polyline. Try Again.")
            opt.AddAllowedClass(GetType(Polyline), False)
            Dim res As PromptEntityResult = ed.GetEntity(opt)
            If res.Status <> PromptStatus.OK Then
                Exit Sub
            Using tr As Transaction = db.TransactionManager.StartTransaction
                Dim poly As Polyline = tr.GetObject(res.ObjectId, OpenMode.ForRead)
                Dim cPoly As Entity = poly.Clone
                cPoly.ColorIndex = 2
                rcTrans = New Transients.RegenClearTransient(cPoly, aDoc)
                tr.Commit()
            End Using
        End Sub
cadVDJ3M
Thanks @hippe013 since the @norman.yuan talked about transients I've been researching this, but I haven't found such an effective way to eliminate them in a simple way through Regen..
I'll convert this code to C# (ie good because I learn more).
cadVDJ3M
Thank you @hippe013  and @norman.yuan  , with the tips provided I managed to solve the issue and understand how Transient Graphics works.
Here the solution I applied, a simpler code that meets my needs.
The idea of ​​monitoring events is fantastic, and it can be useful for many things... I like this.
Here is the final code, with a lot of help from the web.
using System.Collections.Generic;
using System;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.GraphicsInterface;
using Autodesk.AutoCAD.ApplicationServices;
using AcadApplication = Autodesk.AutoCAD.ApplicationServices.Application;
using AcadDocument = Autodesk.AutoCAD.ApplicationServices.Document;
namespace MyTransients
    class MyTransients
        public static List<Entity> entities = new List<Entity>();
        public static bool IsMonitoring = false;
        public static void CreateTransient(Entity ent)
            entities.Add(ent);
            TransientManager.CurrentTransientManager.AddTransient(ent, TransientDrawingMode.DirectShortTerm, 128, new IntegerCollection());
            MonitorCommandEvents_Method(); // Initialize Commands Events Monitor
        public static void ClearTransient()
            foreach (var item in entities)
                TransientManager.CurrentTransientManager.EraseTransient(item, new IntegerCollection());
                item.Dispose();
        #region Event Monitor, to capture Autocad Commands
        /// <summary>
        /// Initialize event monitor
        /// </summary>
        public static void MonitorCommandEvents_Method()
            if (!IsMonitoring)
                SubscribeToDoc(AcadApplication.DocumentManager.MdiActiveDocument);
                IsMonitoring = true;
        /// <summary>
        /// Monitored events
        /// </summary>
        /// <param name="doc"></param>
        public static void SubscribeToDoc(AcadDocument doc)
            doc.CommandWillStart += new CommandEventHandler(doc_CommandWillStart);
            //Disabled for future use
            //doc.CommandEnded += new CommandEventHandler(doc_CommandEnded);
            //doc.CommandCancelled += new CommandEventHandler(doc_CommandCancelled);
            //doc.CommandFailed += new CommandEventHandler(doc_CommandFailed);
            //doc.UnknownCommand += new UnknownCommandEventHandler(doc_UnknownCommand);
        static void doc_UnknownCommand(object sender, UnknownCommandEventArgs e)
            (sender as AcadDocument).Editor.WriteMessage(string.Format("\nCommand {0} unknown.\n", e.GlobalCommandName));
        static void doc_CommandFailed(object sender, CommandEventArgs e)
            (sender as AcadDocument).Editor.WriteMessage(string.Format("\nCommand {0} failed.\n", e.GlobalCommandName));
        static void doc_CommandCancelled(object sender, CommandEventArgs e)
            (sender as AcadDocument).Editor.WriteMessage(string.Format("\nCommand {0} cancelled.\n", e.GlobalCommandName));
        static void doc_CommandEnded(object sender, CommandEventArgs e)
            (sender as AcadDocument).Editor.WriteMessage(string.Format("\nCommand {0} ended.\n", e.GlobalCommandName));
        static void doc_CommandWillStart(object sender, CommandEventArgs e)
            if (e.GlobalCommandName.Equals("REGEN", StringComparison.CurrentCultureIgnoreCase))
                ClearTransient();
        #endregion
Forma Design Contest
