I have a command that will pull data from a SQL database and import it into a title block. This worked fine in .net framework. I recently migrated to 2025 and .net 8.0 and I am getting the following error: System.PlatformNotSupportedException: 'Microsoft.Data.SqlClient is not supported on this platform.'
I created a test console app in .net 8.0 and I am able to pull data from that database that way. Has anyone else run into this issue?
Solved by CBennett34F8SS. Go to Solution.
nevermind I found it, for some reason Microsoft.Data.SqlClient is not choosing the correct runtime .dll to load. I specified it in my project file with <RuntimeIdentifier>win-x64</RuntimeIdentifier> and it is now working again.
For anyone else :
I noticed this today
https://adndevblog.typepad.com/autocad/2024/05/connecting-to-sql-server-from-autocad-2025.html
Perhaps this article by Madhukar Moogala @moogalm will help those with an SQL issue.
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>; another Swamper
<RuntimeIdentifier>win-x64</RuntimeIdentifier> was the Solution!
Perhaps ypu guys need to look at this :
https://github.com/MadhukarMoogala/ACAD-SQLPlugin
From 3 months ago.
I have also strugled with this when i first tried to get all my tools to work in .net 8.0 i also use a sql database and there wasnt allot of info around at the time. Im glad to see that there are now
