.NET
Clear Selection on screen OR Select none
4 REPLIES 4
3211 Views, 4 Replies
--Or you can just PInvoke acedSSSetFirst, which is what
the SelectObjects() method does.--
My limited training materials does not tell me how to get the acedsssetfirst selection set, I want to clear it out.
I used:
Autodesk.AutoCAD.Internal.Utils.SelectObjects(ids);
to get some objects for zooming, and now I want to un-select them for the user to move on.
In vba i could get a selection set by name from a group of selection sets in the drawing. Can I do that in .net?
jvj
4 REPLIES 4
SRSDS
Would anyone have a solution for this? I can't find a solution elsewhere.
SendingString cancels my current command. And trying to set a selection set with Nothing in it creates an error.
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.SendStringToExecute(Chr(27), False, False, False)
psr = Nothing
ed.SetImpliedSelection(psr.Value)
Alfred.NESWADBA
in reply to: SRSDS
use this: 😉
tAcadDocED.SetImpliedSelection(New ObjectId() {})
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
SRSDS
in reply to: Alfred.NESWADBA
I did try something similar but it also didn't work.
'Dim arOBJIDS(0) As ObjectId
'arOBJIDS(0) = Nothing
'ed.SetImpliedSelection(arOBJIDS)
Thanks once again!!
Alfred.NESWADBA
in reply to: SRSDS
HI,
you have an array declared with one item, I did declare an array with 0 items, that's the difference.
Anyway, good to hear it's working now for you!
- alfred -
Alfred NESWADBA
Forma Design Contest
