.NET
changing visibilty is changing block name
4 REPLIES 4
kshitij_jadhav
252 Views, 4 Replies
when i change visibilty one of the visibility is giving block reference name as "U99" when checking in debug mode. Are there any fix for this?
4 REPLIES 4
_gile
in reply to: kshitij_jadhav
This is the way dynamic blocks work. As soon as you edit some dynamic properties of a dynamic block reference, AutoCAD creates a new anonymous block definition (BlockTableRecord).
You can retrieve the name of the original block definition via the DynamicBlockTableRecord property of a block reference.
Gilles Chanteau
GileCAD
GitHub
kshitij_jadhav
in reply to: _gile
is there a workaround to avoid block name change
That is how dynamic block works. Workaround? If you really want to work around the block reference becoming anonymous block, then do not use dynamic block; or, only insert the block reference with its original dynamic properties and do not change them (then why use dynamic block at all?).  You may want to explain why you have such a unusual requirement.
Norman Yuan
Drive CAD With Code
The workaround is to fix your application's design so that it does not rely on the names of anonymous blocks.
An app or plugin should never rely on the names of anonymous blocks, for the reasons described above, and because an anonymous dynamic block reference can be copied any number of times. When that happens, all of the copies reference the same anonymous dynamic block. When one of the copies is modified, it will reference another new anonymous block having a different name, while the other unmodified copies will still reference the previous anonymous block.
Describe your need for depending on anonymous block names, and perhaps someone can suggest a way to resolve it, but there is no workaround that can prevent an anonymous dynamic block's name from changing when the user modifies its properties.
Forma Design Contest
AutoCAD Beta
