.NET
Call rejected by callee
1 REPLY 1
sivaulagu
1187 Views, 1 Reply
Dear all,
when i connect autocad through vb.net i get the COM exception, this error occured earlier, i'veused Threading.Thread.sleep(10000), that timeit worked,but again now im facing same issue now.
kindly help
1 REPLY 1
http://through-the-interface.typepad.com/through_the_interface/2010/02/handling-com-calls-rejected-b...
Facebook | Twitter | LinkedIn
Expert Elite Member
Forma Design Contest
AutoCAD Beta
