public static void InsertBlock(Database db, Editor ed, Point2d center2d, double rotationAngle, string blockName, string layerName)
try
string blockNumberString = mmsBlockNumber.ToString();
if (blockNumberString.Length == 1)
blockNumberString = "0" + blockNumberString;
// Start a transaction
using (Transaction trans = db.TransactionManager.StartTransaction())
// Open the Block table for read
BlockTable bt = (BlockTable)trans.GetObject(db.BlockTableId, OpenMode.ForRead);
// Check if the block definition exists
if (!bt.Has(blockName))
ed.WriteMessage("\nBlock \"" + blockName + "\" not found.");
return;
// Get the block definition
ObjectId btrId = bt[blockName];
BlockTableRecord btr = (BlockTableRecord)trans.GetObject(btrId, OpenMode.ForRead);
// Open the current space (model space or paper space) for write
BlockTableRecord currentSpace = (BlockTableRecord)trans.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
// Create a block reference
BlockReference blockRef = new BlockReference(new Point3d(center2d.X, center2d.Y, 0), btrId);
if (!layerName.Contains("Earth")) blockRef.ScaleFactors = new Scale3d(2, 2, 1);
blockRef.Layer = layerName + " BL-" + blockNumberString;
// Add the block reference to the current space
currentSpace.AppendEntity(blockRef);
trans.AddNewlyCreatedDBObject(blockRef, true);
// Rotate the block reference
string basePoint = center2d.X.ToString() + "," + center2d.Y.ToString();
ed.Command("rotate", blockRef.ObjectId, "", basePoint, rotationAngle);
// Commit the transaction
trans.Commit();
catch (Autodesk.AutoCAD.Runtime.Exception ex)
// Log specific AutoCAD exceptions for the entire function
Log.Logger.LogException(ex);
catch (System.Exception ex)
// Log any other general exceptions for the entire function
In above code (.NET api), i am trying to add blockreferences in my drawing and it is working perfectly, but if I add blockreferece once, and after that if i add blockreference again and call regen command, the blockreference added first time got disappeared, what should I do?
You SHOULD NOT call Editor.Command() for rotating the new BlockReference within the Transaction, while it has not been committed.
You can simply set the Rotation property of the block (if there is not AttributReference in the BlockReference and the roration is based on the insertion point.), or call TransformBy() to rotate it:
var mt=Matrix3d.Rotation(rotationAngle, Vector.ZAxis, basePoint);
blockRef.TransformBy(mt);
got the error, actually, in other function, i am erasing the blocks by mistake
