Autodesk viewer
Autodesk viewer
tlabbeLE97E
Message 1 of 8
Autodesk viewer
tlabbeLE97E
Can the autodesk viewer display files that I host locally?
https://aps.autodesk.com/en/docs/viewer/v7/developers_guide/overview/
I have a server app where users can upload their floorplans and I want to display them in the viewer.
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
@tlabbeLE97E Are you wanting help navigating the SDK https://aps.autodesk.com/viewer-sdk
Do you have to sign up to their Developer Network first to gain access? They have their dedicated forums.
Message 3 of 8
tlabbeLE97E
yes I have signed up for an account. Do you know the name of their forum? I tried to find a "Viewer" forum but am did not see one in the Autodesk Forums list.
Message 4 of 8
Ed__Jobe
I don't believe that the viewer can be hosted locally. APS is an online solution. However, you can open the files in one of the free viewer apps.
Design Review and DWG TrueView
Ed
How to post your code.
Message 5 of 8
CGBenner
@tlabbeLE97E
You are correct that there is no dedicated forum for the online viewer.  The free viewers mentioned by @Ed__Jobe do have forums of their own if you decie to try one of those.  Good luck!
Chris Benner
Message 6 of 8
prem_kumar8SXZJ
Hi @tlabbeLE97E , You can not host Autodesk Viewer locally because it's an online viewer which is hosted on Autodesk Servers. So everytime you try to view a CAD file it send an API request to the Autodesk server and then the file is processed online, so in short no you can not use the Autodesk Viewer locally.
But if you are a software develeper then there are plenty of libraries that lets you read and write DWG, DXF files, One library is AcadSharp written in C# you can try that. And for viewing DXF files there is a library in Javascript which you can search on NPM. Hope this resolve your query.
Message 7 of 8
tlabbeLE97E
Thanks for the help everyone. I guess this viewer is not what I am looking for.
@prem_kumar8SXZJ - Thank you for the suggestions I will look into those. Much Appreciated!
Message 8 of 8
velprakash567
Community Visitor
Community Visitor
I'm working on viewing the converted svf file in web browser. Could you please share any documentation/library available to render the converted file in browser using js?
